Dakota Digital Releases Two New Expansion Modules!
August 2, 2023 By Tim King
Dakota Digital Interior Light BIM Module
Our new BIM-RGB accessory module allows you to control LED accent lighting within your vehicle.  The BIM-RGB can be used as a stand alone or with Dakota Digital gauge systems allowing you the ability to sync your interior lighting with the color scheme of your gauges!
Like the other similar BIM’s, this unit retails at $119.95.
https://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=1368/category_id=-1/mode=prod/prd1368.htm
Here is a list of features for the BIM-RGB:
  • Output designed for 12VDC RGB LEDs, common anode configuration.
  • BIM-RGB can be synced to match other Dakota Digital HDX/RTX/GRFX color schemes.
  • Can also be used as a standalone RGB LED controller.
  • Outputs for up to four strings of LED’s.
  • Each of the four outputs can drive up to 32 inches of LEDs.
  • Optional switch inputs to support custom installations.
  • 31 LED color selections to choose from.
  • Programmable via Bluetooth with the Dakota Digital Accessory app.
  • Selectable Music Mode flashes the LED’s to the beat of the music
Dakota Digital FiTech BIM Module
We have a new BIM module to add to our list of supported aftermarket EFI manufacturers.  The BIM-01-2-FTCH fits new FiTech LS, TBI and TCU applications.
https://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=1367/category_id=-1/mode=prod/prd1367.htm
The BIM-01-2-FTCH is designed to read the engine information from new FiTech EFI kits.  The BIM-01-2-FTCH module is connected to the units with a supplied 2.5mm “Y” harness allowing the handheld controller to remain functional.
Filed Under: feature article, forum feed, news feed
Copyright © 2023   · Lateral-G · All Rights Reserved ·
