EASY LSA UPGRADE FROM SUPERCHARGERS ONLINE
Superchargers Online’s new LSA Performance Inlet lets Chevrolet Camaro ZL-1 and Cadillac CTS-V owners get more boost out of their superchargers with minimal effort.
SIMI VALLEY, Calif. (May, 2017) – Superchargers Online, a leading distributor of superchargers and superchargers parts, is excited to announce its new LSA Performance Inlet. Built using brand new EATON factory parts, this performance inlet is a direct bolt-on upgrade for the Chevrolet Camaro ZL-1 and Cadillac CTS-V, and is available with two different size ZPE/SCOL GripTec® performance pulleys.
The LSA engine was one of General Motors’ first factory supercharged V8 engines, and when it hit the streets in 2008 under the hood of the Cadillac CTS-V, it didn’t take tuners long to start trying to extract more power. Until now, increasing the boost output from the LSA’s EATON TVS1900 supercharger meant using a hydraulic press to remove the factory pulley and then either press on a new pulley or a hub that can accept bolt-on pulleys. Now, Superchargers Online has taken the work out of the LSA pulley upgrade with its new bolt-on LSA Performance Inlet.
Superchargers Online’s LSA Performance Inlet is built using brand new EATON factory parts including a new inlet casting, new bearings, and a new bypass actuator. Increased boost comes by way of the preinstalled ZPE/SCOL GripTec® pulley which features ZPE’s patented micro machining process for increased friction between the pulley and drive belt to reduce slippage. Multiple pulley options are also available to allow owners to match the boost increase to a variety of engine upgrades – from 2.55-inches down to 2.38-inches for up to a 5psi gain.
The LSA Performance Inlet is a direct bolt-on upgrade for the 2009-2013 Cadillac CTS-V, the 2012-2015 Chevrolet Camaro ZL-1, and the Chevrolet Performance LSA crate engine, will require recalibration of the ECU. Made in the USA and backed by a 30-day warranty against manufacturer defects, the inlet comes with all parts necessary for a complete installation, including new mounting hardware, a new EATON Solid Isolator, and RTV sealant. The LSA Performance Inlet is not legal for use on pollution-controlled vehicles. For more information on the LSA Performance Inlet or Superchargers Online’s other products, visit www.superchargersonline.com.
About Superchargers Online
Founded in 1999 and headquarted in Simi Valley, California, Superchargers Online is the largest distributor in the world for superchargers and supercharger parts from companies like Magnuson Superchargers, Edelbrock, Roush, SLP, Vortech, and Procharger. Superchargers Online is also the only Eaton Authorized Service Center in North America and offers Eaton Original Parts for service and repair as well as repair and rebuild services for all Eaton-based aftermarket and OEM superchargers. For more information, visit www.SuperchargersOnline.com.
