Old 02-26-2009, 06:10 AM
67ragtp 67ragtp is offline
Default Katech coil relocation bracket
Can someone tell me where the main bracket mounts, looking at pictures of the bracket its difficult to understand where its actually bolting to. Is it the inside surface of the valve covers or intake manifold mounting bolts? Do they require modifying the valve covers?
Thanks Rich
Old 02-26-2009, 06:21 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I think it's pretty slick, I like the design.
Katech Inc. designed coil relocation brackets to attach to the backside of our cast aluminum valve cover. This kit was designed to leave the cover bolts accessible for easy removal and installation of the valve cover assembly. Also Included in the kit is a set of 8 MSD spark plug wires. These wires retain the same resistance as the factory wires so there won’t be any interference with other delicate electronic devices. Recently updated with a new modular design, these brackets slide on a rail to accommodate any setup.
Edit, here's a close up of how it mounts:
My LS7 69 Camaro
Old 02-26-2009, 09:14 AM
ironworks's Avatar
I can give you some more info next week we just prdered some valve covers and coil brackets for a project we have.
Old 02-26-2009, 09:34 AM
Steve1968LS2's Avatar
Thanks Rich
Yea, to the inside vertical plane of the valve cover.
It's what I'm running on Penny, very nice design. The main functional benefit is that you don't have to pull the coils to remove the valve cover.
Old 02-26-2009, 09:40 AM
You can see here.. imagine the fasteners like Scott showed holding it the valve covers. The VCs are drilled and tapped for the bolts and there are around 5 per a valve cover.
Old 02-26-2009, 09:50 AM
I haven't been too fond of the newer gen stuff just because the engines often look all cluttered with the extra electronics and prefer the old school stuff from an aesthetics perspective. However, I must admit that dayum, that sure is purty :-)
John
Old 02-26-2009, 09:58 AM
youthpastor's Avatar
yep pretty basic- u need to space the coils before u tighten them down- very easy
Old 02-26-2009, 11:05 AM
Thanks Guys- so your pretty much stuck buying there valve covers to mount them. I was wondering if I could mount them to a set of gm center bolt competition Chevrolet valve covers. I amagine the threaded holes in the inside verticle plain of your VC's must have a casted boss. The Katech covers aint cheap, the gm chevy covers are nice for 110 bucks per.
Thanks again Rich
Old 02-26-2009, 01:09 PM
Thanks again Rich
i got mine from LS1 tech classifieds- I've seen em for $300- well worth the money
Old 02-26-2009, 04:18 PM
xtremelky's Avatar
xtremelky xtremelky is offline
Thanks again Rich
No Rich. You can mount them to others VC.
Mike
