Old 04-01-2009, 07:03 PM
vannatta20 vannatta20 is offline
Default 4 gen LPP header install in First Gen firebird
They dont fit perfect but they will work. They are stainless steel and cost 500$. I have unisteer rack and pinon steering and I just have to put a very small dent to clear. My problem is the crossmember. It is smack dab in the middle of my headers. I need to either cut up the crossmember or route the exhaust under it but then it will hang low to the ground in that spot. Any ideas?
Old 04-01-2009, 07:05 PM
Old 04-25-2009, 08:17 AM
D Rock D Rock is offline
What brand crossmember is that? My ATS tucks up alot higher so the exhaust can run under it. I would look into it.
Old 04-25-2009, 11:30 AM
Rybar's Avatar
Rybar Rybar is offline
I'd also try the latest version of the ATS x-member. It tucks up tight to the floor and gives alot more header clearance.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 04-27-2009, 11:28 PM
indebt69's Avatar
indebt69 indebt69 is offline
Ahhhh, good ole S&P crossmember. Exactly what I'm using on my car. I need to look at mine exactly but I also don't have much clearance. Just hate paying $300 something for a new one. Not too impressed with the S&P stuff here lately. I had to use Car Shop 1" setback plates and it barely matches up with the crossmember. That one isn't adjustable so it sets where it sets
Old 04-28-2009, 06:40 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Headers look good, but man, that crossmember has issues.
My LS7 69 Camaro
Old 05-22-2009, 08:45 AM
I figured out what to do. I will cut the S&P crossmember up and use 4 inch square tubing and create a notch for the exhaust to go through. Will post some pics. I should have got a ATS but didnt have enough funds for that.
