Old 12-16-2015, 12:12 PM
JON Q's Avatar
JON Q JON Q is offline
we did ARP's on a 68.
5/16" x 18 x 1" fender/sheet metal
5/16" x 18 x 3/4" fender/wheel houses
5/16" x 18 nuts fender/header panel
3/8" x 16 x 2" fender to body
3/8" x 16 x 1" hood hinges
5/8" x 11 x 3" frame to body
3/4" x 10 x 1 1/2" bumper bracket
3/4" x 10 nuts bumper bracket
Would these be the same size for a 69?
Old 12-16-2015, 01:34 PM
yes. add a bunch of screws to the list
Old 12-16-2015, 01:36 PM
Originally Posted by MtotheIKEo View Post
You're fine. I believe Carl is referencing SS bolts found at your local hardware store. They generally have a pretty low UTS, about as strong as a Grade 2 bolt. The below link shows what is typically found at hardware stores, 70ksi tensile strength....
http://www.mcmaster.com/#socket-head...crews/=109atn3
ARP, DSE body bolts, etc... are VERY strong. See the link below for McMaster-Carr 12-point stainless cap screws with 170ksi tensile strength.
http://www.mcmaster.com/#standard-cap-screws/=109aspp
Link to ARP's stainless explanation (also 170ksi tensile strength)
http://arp-bolts.com/p/technical.php
mcmaster carr sells arp but its higher cost than summit or direct
what i usually do is figure out what size i need then say if its a 5/16" x 18 x 1" bolt I'll look for a differential kit. 12 bolt chevy kit has 12 bolts 5/16" x 18 x 1" with washers. if you buy them separate or a 5 pack they will cost average is $2.40 a bolt plus the washers. it a 12 bolt diff kit you may spend $1.75 per bolt and that comes with the washers.
same with the 3/8" x 16 x 1.25" bolts, i'll buy a chevy intake manifold kit, 12 bolts w/ washers for $2.91 each and the 5 packs are $3.10 each. every little penny helps
Old 12-16-2015, 02:20 PM
JON Q's Avatar
Thanks!!
Old 12-16-2015, 06:03 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
Yeah, I was going to do all arp fasteners for the entire car. Then I priced it out. Hell no, that was some serious cash. I just did all arp for the engine only.
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 12-16-2015, 06:14 PM
CarlC CarlC is offline
This.
But, it also applies to the stainless fastener kits sold by the repro parts houses. From a structural standpoint, most all of it is of unknown quality, specifications, etc. I trust none of it.
Let's not delve into proper length specifications for double shear just yet either. ..... ;-)
http:www.vaporworx.com
Old 12-16-2015, 08:07 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I hear you. Just doing the few that I am and my motor isn't cheap. It's one of those things that I really like the look of though, so it's worth the over time.
Curtis
Old 12-16-2015, 09:11 PM
buy ARP bolt kits
Great tip! I've looked into ARP bolts but the cost is crazy. This makes it more reasonable.
Old 12-16-2015, 09:12 PM
One of my biggest pet peeves with suppliers. Not providing proper bolts for their kits. Threads cutting up mounting tabs and being mounted in shear.
Old 12-18-2015, 11:06 PM
Even the OE parts are like this. After using the correct AN standard fastener it's hard to consider going back except on resto-builds.
