  #17
Old 03-11-2015, 08:43 PM
Ron Sutton's Avatar
Originally Posted by JSM View Post
Ron,
As usual, thank you for taking time to answer, and in detail, but I think I did not ask my question clear enough. I was not needing the entire full floater rear-end set-up weight because I know there are many variables.
What I was trying to figure out is the weight ONLY for the items that I had listed. So basically if you took the components I have listed again, throw them on a scale,,,, what do they weigh?
(1) Snout -
(1) Hub (steel or aluminum? -
(2) Bearings/Races -
(1) Drive Plate & Cap (I assume you run steel) -
(5) Studs -
(1) Caliper Bracket/gussets) -
Thanks in advance, Jay
Hey Jay,
Next time I'm at my shop ... which isn't often ... I'll grab those parts and weigh them. They are going to be heavier than the C6 ends and assembly. I'm just not sure how much heavier.
Ron Sutton Race Technology
