Old 05-22-2020, 05:38 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by DKz Garage View Post
Mark...... I wonder if you would have some input on brake line size. I know a lot of your recent builds have ABS. What size brake line do you use? I'm using the DSE master (GM part) and booster on my 69 ...I will be making all my own brake lines and was looking to use 3/16" for the entire car. I know GM used 3/16 in the front (disc brakes) but ran 1/4" to the rear? Could you shed some light on what you normally do with your cars?? Thanks in advance.
On my builds I do 1/4 lines to the ABS module and 3/16 to the corners. In general if you copy what GM does it will work. GM and most OEMs are either cheap, worried about safety or durability. For ABS the bigger line is need to supply the volume of fluid needed for the ABS module. For a passive system that you are not gong to track 3/16 for everything should be good. If I was going to track the car with big brakes I would do 1/4 to the tee for the front and rear systems, Then 3/16 to the corners.
Mark
Stielow Engineering
The Following 8 Users Say Thank You to Stielow For This Useful Post:
69hugger (05-23-2020), camcojb (05-22-2020), colorado80439 (05-22-2020), DKz Garage (05-22-2020), Goosesdad (05-22-2020), kwhizz (05-22-2020), syborg tt (05-29-2020), WILWAXU (05-23-2020)
