Old 03-01-2023, 03:21 AM
srode1 srode1 is offline
Thumbs up
Thanks, I was trying to figure out how to fit a 200 in mine and it's a challenge, the 100 is a much easier fit. If you find anything in your 'spare' time on the difference between the two provent 100 options I'd be very interested will use the part number you listed otherwise.
On edit - after some quick research - the differences are one version has a bypass which is the part number ending in 3. The part number ending in 2 has a pressure relief valve. Based on the naming I would guess the bypass routes excess through the outlet which most would route to the air intake tube, and the pressure relief valve vents excess externally. The version version ending in 2 is called 'off road' probably due to the routing of the relief valve gasses.
