Old 10-07-2012, 07:13 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by monza View Post
Do you have much of a specific break in routine you try and adhere to?
I try to put 200 easy break in miles on the diff and trans. I've done that on the last couple cars and it helps keep the diffs quieter. You should vary speed and load and if you have coolers cycle them also to keep them cool. It is time well spent to check for leaks and loose parts also.
On a side note if you purchase a new car you should do the same. But you don't need to look for loose parts.
Mark
