Old 10-06-2007, 04:13 PM
73ta's Avatar
73ta 73ta is offline
Talking New to Here
Hey all. I'm new to here. Been on most of the other Pontiac boards for years. Looking forward to chatting with all of you.
Old 10-06-2007, 05:46 PM
Jay's67SS's Avatar
Jay's67SS Jay's67SS is offline
Is that your Screamin Eagle for your avatar? If so nice ride! I see you're a Lodanian, I've got family out there. My uncle owns Dennis' Country Kitchen.
Old 10-06-2007, 06:24 PM
class67's Avatar
class67 class67 is offline
Welcome from Tracy! nice car.
Old 10-07-2007, 07:13 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Welcome. Post up some pics.
My LS7 69 Camaro
Old 10-07-2007, 04:52 PM
73ta's Avatar
Yep, the avatar is it. I'm stuck in Lodi! I'll post a few more after I shrink them.
Old 10-07-2007, 09:53 PM
aany001's Avatar
aany001 aany001 is offline
welcome aboard...
Old 10-07-2007, 10:03 PM
welcome, great looking car. I'm only 15-20 minutes away in Wilton.
Old 10-08-2007, 12:12 PM
73ta's Avatar
Great to see a lot of n Cali people here. I look forward to seeing some of you at the local tracks & shows. I'm easy to find as I'm usually the only 2nd gen TA at any given event!
Old 10-08-2007, 01:08 PM
73ta's Avatar
A few pics and some info:
General:
Year:1973
MakeONTIAC
Model:TRANS AM
Curb Weight : 3,873 w full tank
Race Weight : 4,080 w full tank
Chassis:
Front Suspension:Stock springs, KYB SHOCKS, POLY BUSHINGS & arm mounts
Rear Suspension:Stock springs, KYB SHOCKS,POLY BUSHINGS
Rear Axle:3:42 Posi
Brakes:Front stock, REAR DISK WS6
Wheels & Tires:AR TTII,17" X 9.5 , 5.5” BS "FRNT & REAR, 285/40 REAR, 275/40 FRNT
Misc:CE SUB-FRAME CONNECTORS, aluminium body mounts, alston front chassis braces, POLY CONTROL ARM & SWAY BAR MOUNTS
WS6 fast ratio steering box, (12:1) with small rag joint
1 ¼” front sway bar, 7/8” rear sway bar
Paint & Body
Color:WHITE, CLEAR/BASE
GraphicsHOENIX GRAPHICS
Interior
Seats:Custom Stock
Upholstery:CUSTOM STOCK
Carpet:STOCK
Dash:INSTALLED FACTORY AC in NON AC CAR
Gauges:STOCK
Shifter:HURST COMP PLUS
Stereo System:ZAPCO JBL & SONY, MEGA WATT!
ADDED FACTORY PWR WINDOWS & DOOR LOCKS
Engine, Fuel, Ignition & Transmission
Type:455, .035, 530 HP, 570 lbs Tq
Camshaft:COMP CAM HYD ROLLER 236/.520” intake, 242/.550” exhaust, 110 sep.
Cylinder Heads:EHEADS PORTED 87cc, flow 307,215
Valvetrain:HARLAND SHARP RR 1.5
InductionERFORMER RPM, PORT MATCHED
Fuel: 3/8 lines carter electric pusher with carter mechanical feeding 800 cfm Cliff modified quadrajet
Exhaust Doug's Headers, Flowmaster American Thunder system
Transmission:M21 with poly mount
Cooling:BCOOL WITH 2-10" ELECTRIC FANS, push, stock flex fan ,pull. AC pulleys
Mity Mount engine mounts
10 bolt posi rear, 3:42 ratio
MSD 6AL Spark Box
MSD Billet Distributor with polymer gear
MSD Blaster Coil
A work in progress!
Old 10-09-2007, 01:29 AM
Rybar's Avatar
Rybar Rybar is offline
That is a sweet T/A!! I've always wanted to see somebody PT one. Nice job
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
