View Poll Results: Which one would you choose and why?
Alterkation front with Lateral Dynamics rear (does not use panhard bar) 12 60.00%
XV Level II front with XV Level II rear (does use panhard bar) 8 40.00%
Voters: 20. You may not vote on this poll
Old 11-09-2007, 02:00 AM
deuce_454's Avatar
Originally Posted by Silver69Camaro
I differ from this opinion. A well-designed panhard bar can work extremely well, and does not suffer from the usual drawbacks of a watts (complexity, cost, weight, and exhaust room).
in your case i can see why youŽd object.. but or your chassis (AM) the roll-center in the rear is so well controlled and low set with the rear UCAŽs mounted where they are.. but when upgrading anything on a car my philposophy has always been to get it as good in the first go as is possible...
and the point of exhaust room on a cuda -that with a fair degree of certainty will have exhaust exiting before the rear wheels... isnt a sure seller.
Jake: Hit it.
Old 11-09-2007, 02:35 AM
JohnC JohnC is offline
Originally Posted by Bowtieracing
No with XV i wouldn think of an second to to choose their stuff.
What??
Old 11-09-2007, 02:44 AM
my philosophy as well...
I kind of wanted to use the lower rear facia with exhaust thru it...Is that going to be possible with the Lateral Dynamics stuff??? They say you can, but I have not seen a LD car yet the rear exiting exhaust....
Old 11-09-2007, 03:21 AM
Originally Posted by JohnC
What??
Once again and slowly....
Now when we have XV motorsport on market i would choose their stuff over everything i have heard or seen sofar. I believe they have invested a lot for testing and R&D of their products.
Got it ?
63 Z06
Old 11-09-2007, 05:55 AM
Got it ?
Ok, that makes sense.
Old 11-09-2007, 06:31 AM
I sometimes do type faster than i think
63 Z06
Old 11-10-2007, 09:41 AM
James OLC's Avatar
I had no issue running a complete mandrel bent 3" exhaust system exiting at the back of the car with the Lateral Dynamics 3-Link. The rear crossmember is even notched for clearance. Steve Rupp is likewise running a full exhaust system. It's not much more difficult with the LD setup than any other rear suspension.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 11-10-2007, 10:17 AM
Steve1968LS2's Avatar
Yea, I could have ran 3-inch if had wanted to but the 2.5 was perfect for the size of my engine.
There's plenty of room if the exhaust fabricator has some talent.
Old 11-10-2007, 10:20 AM
You can't say that any longer..
Old 11-10-2007, 12:38 PM
Mean 69 Mean 69 is offline
Thanks for all of the kind words guys, and the interest from all of you. I owe the thread a response, and I will get to it hopefully before the weekend is over with some relevent info. No time to type more right now.
Cheers,
Mark
