Old 05-02-2008, 07:23 PM
JUSTANOVA JUSTANOVA is offline
Originally Posted by BBC69Camaro View Post
Given what you said, you might look at smaller runners than the 325s and 310s, given that your intended use is just the street and your RPM range. I have a 489 with pretty similar rpm range and goals that you have, that I wanted as wide a power band as possible. I ended up going with the Brodix RaceRight Oval ports in 270cc, also using a RPM Air Gap. I think any of Dart, AFR or Brodix you can't go wrong with. You might also check out Comp Cams Thumpr line of hydraulic roller cams.
Right now the motor is broken in but not in the car yet, but it has a nice sound on the engine stand, and Desktop Dyno puts it right in the 600 range in torque and hp. 500ft/lbs off idle You can check out my build in my sig.
Whatever you go with you do want to match all your parts to the intended rpm range of your application you will make the most power that way. Look at the RPM ranges of different heads, intakes and cams to help make your selection.
Good luck, and let us know what you go with!
if you havent seen it already check out phr's howitzer buildup
http://www.popularhotrodding.com/tec...car/index.html
they made 626hp and 635 ft/lbs
Project EARTHQUAKE:
72 Nova SS, Plans have changed a little:artmorrison front subframe, and rear 3 link, pretty much stock ls1 and six speed with a single turbo for around 550hp. with a few other things mixed in.
current cruiser: "The green machine"
'70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct
and why do we modify everything...."BECAUSE STOCK SUCKS"
