View Poll Results: Poll: LS3 or LS7 vs. GM Crate Ram Jet 502
LS3 14 31.11%
LS7 25 55.56%
502 Ram Jet 3 6.67%
Other 3 6.67%
Voters: 45. You may not vote on this poll
  #22
Old 06-11-2008, 04:14 AM
tyoneal's Avatar
tyoneal tyoneal is offline
[QUOTE=Stang's Bane;152646]So you are going to boost a 10.7:1 motor that hard?? Better have a good supply of race gas on hand. And it will cost you about $16-$17k in the end.
FWIW, lets look at this.
high compression ls7 short block (multiple sources) ~$6200
Stock LS7 heads with GOOD springs ~$3K
Stock LS7 intake $300
Custom cam ~$400
Other parts (covers, lifters, misc bolts, etc) $1500
$11500 and you have an easy 620-640 NA hp.
Stangs Bang:
You mentioned $11500 and you have 620 hp.
http://www.sdparts.com/product/MMS11...rnKeyWECM.aspx
Scoggin Dickey sells this with 620 hp!, "Turn Key" for $14,000 or $2500 more money.
Can you buy all this for $11,500?
The LS3 427’s heart and soul is the new 4.065 aluminum block. The LS3 designation has a Mast Motorsports engineered camshaft that is custom ground on a Mast Motorsports LS3 cam core. The 427 foundation is a honed and decked LS3 aluminum block with a forged Callies rotating assembly with Mahle pistons that is topped off with Mast Motorsports CNC LS3/L92 heads and a LS3 intake manifold. ARP fasteners are used throughout and Manley pushrods ride on LS3 hydraulic roller lifters. The LS3 427 is the first release of a diverse line of Mast Motorsports 427 Turnkey Crate Engines that are designed for Marine, Muscle Car, Off Road, and Sand Car markets. The LS3 427 HO has a decent lope at idle and peaks at the 620+ horsepower mark. The powerful fuel injected turnkey crate engine is tuned for the street to run on 93 octane and includes an ECM and wiring harness with knock control to adjust timing if 87 octane fuel is used.
Specs:
Type: LS3 7.0L
Displacement: 427 Cubic Inches
Compression Ratio: 10.8:1
Bore x Stroke: 4.070 x 4.100
Rev Limit: 7000 RPM
Crank: Callies
Rods: Callies
Pistons: Mahle Motorsports
Cam: Mast LS7 Core Custom Cam
Heads: Mast CNC LS3/L92 Heads
Intake: GMPP L76/L92 Intake
Valve Springs: Pac 1518 Nitrided Beehive
LS3 Aluminum Block
Plateau Honed to 4.070
True Surfaced Deck
Engine Block Deburred
Blueprinted Shortblock
GM Car Harmonic Damper
ACL Rod and Crank Bearings
Callies 4.100 Stroked Crankshaft
Callies Compstar Connecting Rods
Custom Mahle Motorsports Pistons
Mast Motorsports CNC LS3/L92 Cylinder Heads
ARP Head Bolts
ARP Main Studs
Cometic Head Gaskets
Mast LS3 Core Custom Hydraulic Roller Cam
LS3 Hydraulic Roller Lifters
Manley 1 Piece Chrome Molly Pushrods
Pac 1518 Nitrided Beehive Valve Springs
M-90 Calibrated ECM
Main Wiring Harness
Dash Harness
Air Mass Harness
Trans Harness
EGO Harness
Bosch EGO Sensor
Fuel Pump Harness
Fan Harness
LS3 Intake
GM 90mm DBW Throttle Body
Bosch Dead Headed Fuel Rail
Bosch LS3 Fuel Injectors
Mast 8 Layer Air Filter with IAT Bung
Intake Air Temperature Sensor 560-2218 | info@
Crankshaft Position Sensor
Camshaft Position Sensor
Oil Pressure Sensor
Oil Temperature Sensor
Engine Coolant Temperature
Engine Knock Sensors
Manifold Air Pressure Sensor
Ignition Coils
Spark Plugs
Plug Wires
GM Foot Pedal
GM Starter
Car Water Pump
LS3 Oil Pan
GM Oil Filter
Mobile 1 Synthetic Oil
Engine Break in Oil Additive
I only bring this up as it looks like a Heck of a deal for the money And SD would be stupid to put it out if it was a POS.
No Argument here, just looking for the sweetest deal.
If an inter-cooled Magna Charger was used?
An increase of 40% is not out of the question with the $10,100 550 hp, Engine. Thus, 770 Hp for the Price of a LS7 (Roughly)
Your Quote:
"So you are going to boost a 10.7:1 motor that hard?? Better have a good supply of race gas on hand."
BTW: Maganacharger says:
http://www.magnusonproducts.com/pr02.htm
FAQ:
http://www.magnusonproducts.com/faq.htm
"Should the compression ratio be set at 8:1 like my last blower motor? The deciding factor when building a blower motor is to decide how much boost you plan on running, and what type of gas you will use. Compression tolerance (the amount of compression gas will take before detonation) of 91-octane is 13.5:1. This is just a rule of thumb (there are other factors to consider). In theory, if you run 9:1 compression then the max boost you would want to run is 8 lbs (every pound of boost is 2 CR). On Gen 3 motors we have found that the configuration of the motors is much more forgiving that on a typical 10:1 motor and you can get away with even more boost. These are static compression numbers only. Cam choice has an even bigger determination on what you can get away with........... Most Magna Charger supercharger kits are available with intercoolers. An intercooler reduces the discharge temperature of the compressed air from the supercharger. Physics, in this case Boyles Law, states that when air is compressed it gets hotter. A rule of thumb is that for every 10 degrees that you can reduce the temperature, a 1% power increase can be gained. Even more efficiency is available!
I don't think there is ONE perfect answer, however for between 10K-20K You can build a Hell of a nice Street Friendly Engine.
Ain't life Grand.
TY
Project, "EnGULFed"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
"Chester's '65"
1965 Buick Riviera
