Old 07-01-2008, 08:28 AM
Originally Posted by BBShark View Post
What is the reason for making the return line smaller diameter than the supply? I am using a 3/8 supply line and see that most manufactures use a 5/16 return. Well, I can't find much in the way of -5 AN fittings (5/16) and would like to use -6 AN (3/8) supply and -6 AN return.
Am I missing something? Any reason why this will not work?
should be fine. The only time you have an issue is if the return line is too small to handle the amount of fuel bypassed, and causes the fuel pressure to rise due to the restriction in the return line. If you're running a large race type pump you may need a #8 return, but the #6 should work in most all cases.
