Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Supporting Vendor Group Purchases
  #38
Old 09-08-2005, 08:43 AM
evilzee28 evilzee28 is offline
Originally Posted by camcojb
The brackets we had could be adjusted for height. You could shim them for direction. We have those old brackets, but the bulb used for them is no longer available. So we found a new light to fit the housing and since 99% of the people want them as park/turn signals we never made a new bracket to use them as a driving light. We remove the driving light bulb and replace it with a clear (amber when lit) bulb for park/turn signals. This bulb is much smaller which is why the current bracket doesn't clear the unaltered driving light.
If they were set up for adjustment, will the outer surround still fit the gravel pan apperture ok ie does the surround stay still & the housing move (I hope that makes sense)
what would the cost be for a pair of front lights & for a pair of RS style rears.I'm in no rush for them so if it takes Pasquel a while to make the proper bracketry to take the brighter bulbs, then no problem. Carriage would have to be to Great Britain. Probably about the same as to Jannes in Sweden
