Old 03-25-2009, 01:09 PM
Heidts#14 Heidts#14 is offline
www.heidts.com
Check out the subframe. Question is....how much do you want to spend?
Old 03-25-2009, 05:07 PM
usa-69z usa-69z is offline
Originally Posted by Heidts#14 View Post
www.heidts.com
Hoping to get upper and lower tubulars and Qa1 coilovers , dont mind paying good money for good quality. I do want bolt in with no mods on a stock subframe. I want to sit nice and low all round.
Am i asking too much???
Gav
Old 03-25-2009, 07:31 PM
awr68's Avatar
awr68 awr68 is offline
Sounds like a call to Blake at Speed Tech is in order!
Tony
'68 Camaro
Old 03-25-2009, 08:04 PM
brans72 brans72 is offline
Tyler hard to get a hold of????? I have called 3 times this week and got him each time!!!!!!! I also wanna mention he took the time to talk and give advice!
to Tyler @ ATS. Brandon
Old 03-26-2009, 04:45 AM
dhutton dhutton is offline
If you are looking for a bolt in solution that will allow you to lower the car I suggest you talk to Mark at SC&C about the SPC lower control arms (and uppers). He will also set you up with Varishock coilovers which seem to have less reported problems than the QA1, at least that has been my observation.
Old 03-27-2009, 07:36 AM
http://www.heidts.com/index.cfm/page...rod/prd159.htm
Take a look at our suspension packages
Old 03-27-2009, 10:25 PM
Thanx guys , all becoming much clearer now. so many good products to choose from
Gav
Old 03-28-2009, 08:04 AM
Van B's Avatar
Van B Van B is offline
Just be aware that with DSE you need to separate the ball joints and take the shock out if you want to adjust ride height. As much as I like their products, it was unacceptable to me to find that out after I had it installed. Live and learn I guess.
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 03-31-2009, 12:08 AM
Thanx , yep that would take the fun out of it
Old 03-31-2009, 12:14 AM
Ive had a good look at most kits available now and i think im close on a decision . One thing im curious about is, do any of the coilover kits bring height down more than others???. I see drop spindles get a bad wrap so ill go with tubular A- arms and coilovers . I want the edge of front guard in line or close to rim edge. Like rybar's or vegas69 stance.
What arms get the front down safely?
Gav
