Old 08-13-2009, 12:05 PM
69x22's Avatar
69x22 69x22 is offline
Default 69 pro touring Yenko
I have been on this site for a couple of years now talking and learning from many of you. This site has defiantly helped it's vendors as I have dealt with many from this site. (with great results) The car I have been building is a 69 Camaro with a ProCharged intercooled LS 418 should put between 650 to 700 to the rear. The tranny is a new Rockland T56 6 speed, the rear is a Moser 12 bolt with a G bar suspension, front is a AME subframe and the brakes are 14" Wilwoods. Colors will be black with white Yenko stripes with all of the emblems and the wheels are Fiskes just like on the Mule.
Old 08-13-2009, 12:06 PM
69x22's Avatar
Default Hood
Oh Yeah, that's not the hood that is going on the car.
Old 08-13-2009, 12:10 PM
70rs's Avatar
70rs 70rs is offline
Nice project! That should be killer when it's on the road, looking forward to watching the build.
Old 08-13-2009, 12:16 PM
redfire69's Avatar
Well that's a relief! J/K, looks to be a killer project. Look forward to more pics on the build.
Ron
69 Camaro Redfire
Old 08-13-2009, 12:51 PM
mrr1999's Avatar
mrr1999 mrr1999 is offline
Sounds like a great build. Good luck!
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 08-13-2009, 01:03 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Sounds like you have a great vision for the car! Good luck with the build. Should be striking!
Brent
Old 08-13-2009, 01:36 PM
Rybar's Avatar
Rybar Rybar is offline
Nice build, post some bigger pics if you can. Glad you are not using the large cowl hood.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 08-13-2009, 03:10 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Like Eric said. I'm looking forward to watching/following this build.
If you can post larger pics, if possible, that would be cool.
Old 08-13-2009, 05:29 PM
69x22's Avatar
Default 69
Bigger pictures
Old 08-13-2009, 05:51 PM
Jr's Avatar
Jr Jr is offline
WOW! What a build! i will be watching this one.
Couple of questions for you:
Did you need to modify anything on the ame frame or move the radiator to use the pro-charger?
Are you using the stock pro-charger bracket?
Where did you get the air inlet that is on the pro-charger?
How much clearance do you have to the pro-charger to the radiator?
Is that a d1 or f1?
David
