Old 03-13-2010, 12:56 PM
70rs's Avatar
70rs 70rs is offline
Originally Posted by Musclerodz View Post
Install a Pertronix kit and be done with it.
X2. I have used this system on two differnt engines. (a 4x4 truck and my old 68 camaro 327). I had great results with both. On the truck I actually replaced the Crane system with the Pertronix and it helped overall driveability a little. The Crane system was good, but I like the Pertronix better. FYI this one was on a 383 stroker in a heavy 3/4 ton 4x4 truck that I beat the hell out of. Both times they were used with manual transmissions if that matters. I never used one with an auto so can't comment on any differences in set up.
Good luck!
Eric
Old 03-15-2010, 03:34 PM
g356gear's Avatar
g356gear g356gear is offline
I guess the question now is whether to install the Pertronix Ignitor III with my stock distributor and coil or go to the Pertronix Billet Distributor with the Flamethrower coil.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 03-15-2010, 09:42 PM
70rs's Avatar
If your stock distributor is in really good shape and has no slop or bouncing around (good bushings and cam gear) then use it. If you like the look of the new one and need to replace the stock one then you have your answer. I guess it also depends on what look you want. Stock or not?
Eric
