Old 10-02-2010, 12:07 PM
bearcat bearcat is offline
Default Turn signals stopped flashing
My turn signals stopped flashing but all the marker lights work fine. Is this a fuse problem or grounding problem? They don't illuminate when you put the directional on.
69 camaro with AAW harness.
Old 10-02-2010, 12:18 PM
Rybar's Avatar
Rybar Rybar is offline
I had this problem when I noticed my hazards/flasher switch was accidentally left on. My harness is from painless.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 10-02-2010, 12:20 PM
yeah, that isn't the case. Actually the hazards showed on inside the car but steady. Now it doesn't do anything. I checked for loose wires. I guess I'll be checking and hunting some more.
Old 10-02-2010, 04:45 PM
Check that your flasher hasn't come loose from the circuit panel.
Old 10-02-2010, 04:48 PM
doesn't appear to be.
Old 10-02-2010, 04:59 PM
well after digging, the hazards don't work, but they do light up if I turn them on and step on the brake pedal. Weird. All the bulbs are good and the fuses check out good as well. Any ideas?
Old 10-02-2010, 06:37 PM
well I figured it out. The stock replacement flasher does weird things with LED's. I got a fancy one and now it works fine. Hazards don't flash for whatever reason.
Old 10-02-2010, 07:15 PM
Devil is in the details -- which you left out - the fact that you have LED's. They don't pull enough voltage/amperage to make your OEM style flasher work.
Could have saved you some effort IF you had mentioned that little ditty.
Glad you got it.
Old 10-02-2010, 07:18 PM
Yeah.....I didn't even think of it.While I got ya, any idea why the hazards don't flash?
Old 10-02-2010, 07:34 PM
Check to see if you have SEPARATE hazard flasher. If so -- same problem - you'd need to replace it with a LED flasher.
You have a aftermarket wiring system... so see if there's another flasher - or circuit that is separate from the turn signals. Also - check to see if you have a fused flasher circuit.
