Originally Posted by snappytravis
Thanks for the reply, I cut the l.h. qtr last niight and brought it in, looks better, then will go to the r.h. side once I get the metal work done on the l.h. side, I was afraid that was the kind of reply that I would get, just nature of the beast, I do believe what did you use to grind it a roloc 36 grit or is there something that works better, looks like you have done that a time or two. thanks for the pics,
Actually, that link isn't my work. But I have done it a time or two.
I like to take down the welds with a 3/16x3" wheel on a die grinder, just hitting the weld until I get it down to the sheet metal. Then finish up with a roloc sanding disc. Takes away less of the surrounding metal that way.
