Old 12-20-2010, 06:26 AM
vinz68's Avatar
vinz68 vinz68 is offline
Totally Awesome!!
Vinnie
www.fquick.com/vinz68
Old 12-20-2010, 11:26 PM
74ls1nova 74ls1nova is offline
Originally Posted by MikkoV View Post
And letīs point this out yeat, handles quite well for such basic mods, or what do you say
https://www.youtube.com/watch?v=uifl8TzdMYg
OMG i want to do that in my Nova ASAP!
Old 12-21-2010, 12:04 AM
killerjay killerjay is offline
Default Speed-Tech Parts
Looks like you are having fun with the Camaro, Check our Web site for all your suspension (front and rear) needs. All check out the video galley on our website to see our test car in action. speedtechperformance.com
You can contact me directly [email protected].
I assume that i can get more traction with 4 links, would be lighter and most important easier to setup for different tracks, when leafspings own sprinrate and damping action mess coil-overs setup a bit. Alltough with IRS setup it would be better when entering normal track races.
Now i have few leafs removed from packs and coilovers with relatively soft springs, i can setup overall springrate to correct(ish) level thatway, changing springs to coilovers.
Leafsprings doesnīt make setting shock absorbers that easy, since they have their own ability to do that.
Roll center, i donīt understand much about that area.
And sorry if my english sucks a bit, iīm from Finland. Hope you understand all...
Bodyparts, those are relatively cheap comparing to Jap cars, many guys drive JDM cars in here, when you need something in those, it sucks. And iīve allways wanted to do these things litlle different than everyone else, makes also easier to get sponsors.
Old 12-21-2010, 10:13 AM
conekiller13's Avatar
conekiller13 conekiller13 is offline
That video looks like a test drive from Top Gear.
Dan
Old 12-23-2010, 11:57 AM
MikkoV MikkoV is offline
For Early Camaro Spindle Conversion
# Combine these Steering Arms with an Early Camaro Spindle or our Drop Spindle and Remove up to 13 Additional pounds!
# Allows Excellent Bump Steer Adjustability.
So whit what spindles are these supposed to be used? 1gen or early 2gen?
Ill ask this one again, does anyone know?
Chevrolet Camaro LS3+T56 "-70" Drift & Track
Dodge Charger 500 -70 ???+??? Pro-Touring style project
Opel Manta A 3700 -71 Euro muscle.
Old 01-03-2011, 12:18 AM
Gandalf Gandalf is offline
Paging Steve Rupp.......
Make sure Steve get's a few of those awesome pics and some words to go with. You never know.....
Well done on driving the snot out of your Camaro man!
G.
Old 04-14-2011, 11:18 PM
I am installing accusump and oilcooler but how to attach piping to engine, exhaust manifolds has pretty tight fit
Any hints how to do do it.
This kind of adapter didnīt fit, no room for pipes. there is less than inch from filter to exhaust.
This kind dont work too good either, pipes go too low (for ground clearance) so would need to be connected with 90degree fittings, then those are also pretty wide and it gets tight with exhaust again.
So, hints? And remember, LS3 so M22x1,5mm thread for filter...
Old 04-15-2011, 09:48 AM
Blake Foster's Avatar
Those will only work on a first gen spindle 67-69, the second gen is completly different and taller than the first gen.
Blake Foster
www.speedtechperformance.com
Old 04-18-2011, 02:58 PM
h_leadfoot h_leadfoot is offline
Here you go "neighbor": http://www.lingenfelter.com/mm5/merc...Store_Code=LPE
Got one my self..
Henrik/Sweden
Old 04-27-2011, 03:00 PM
Something has been done during long Finnish winter, main mission was steering and get wheels turn like they should in driftcar. Pics dont link correctly but click the links...
I made new lower control arms, using oldones as base. 7cm longer per side, changed wheels from 8x17et -10 to 8x16 et 8 and tyres from 235 -> 205. Now wheels can turn in THEORY 65 degrees
Then i get rid of old steering box and started to fit rack & pinion steering, i choosed Volvo 240 aluminium core rack, they use these in rally cars here and you can get different ratios to those, I had custom made infernals to that, now 2.5 turns lock to lock, in normal tarvel distance... And added 10cm more lenght to rack, so total travel now 28cm, should be enough....?
Then modified, knucles in right lenght and angle, i made bolt on adapters to knuckles, tested movements few times with those and when it was right made jigs and welded knuckles in those, maintained to keep them symmetrical that way, now it turns that 65 degrees and basically no ackerman at any turning angle. And doesnīt go near to dead angle at full lock, few days well spent
But how to route Steering axle, front crossmember was badly in way. Get 90 degree rotating gearbox to it Pic shows also how i solves upper control arm issue, i moved those from inside of brackets in frame to outside, so those moved 60cm out which correlated lenghtening of lower arms.
And last steering mod was to fit Opel Corsa C steering colum, tilt and elecric Power steering with adjustable sensitivity.
But then front wheel stick out 5cm from fenders, and front end had seen itīs better days also otherwise. So little glasfiber and paint.
Btw. couldnīt afford zipties...
Thats all about steering, not at full lock in this pic yeat.
Then gearbox rebuild, it was kind of "loose" and i managed to do lot of misshifts in last season so in went new ->
-Carbon fiber Blocking rings
-Billet Keys for the 1-2, 3-4, 5-6 and Reverse Synchronizer Assembly, with stronger springs for keys
-T56 3-4 Steel Shift Fork, used in Viper, standars aluminium is weak link
-3-4 Synchronizer Assembly. Complete new.
-Bronze fork pads for all shift forks.
Im glad i did it, feels completely different to shift. Otherwise nothing fancy changes in engine, otherwise than adding accusump -> Canton Racing Products 24-026 - Canton Racing Accusump Oil Accumulators - Overview - SummitRacing.com
to make sure that engine has alwas oil and oilcooler.
To rear axle, i decided to get rid of leaf springs and go with Four-link setup. I got Competition engineering universal kit and that assembly is in progress right now. Final gear ratio is also going to change from 1:3.72 to 1:4.1 so fourth gear will also get in use. And axle shafts change to Mosers stronger ones.
And one more, polished it for car to :-)
