Old 12-19-2010, 11:45 AM
MikkoV MikkoV is offline
Default My Camaro "70" LS3+T56 Track & Drifting, Lot of pics and vids
Hi, found this forum recently, or someone in nastyz28 adviced to ask about something from here.
Let me introduce my project(s) and what have i done so far. Gues little different what you guys have used to but bare with me.
First one is 1978 Camaro, i have driven Drifting at pretty serious level for five years now, allways with vintage cars (european) but decided that i want something different. From cars and about driving itself. I did Camaro that way that i can drive also track races in Historic Race Finland series called Roadsport V8, car was originally builted to that class and i did rather minor modifications it to use it at Drifiting, so itīs easy to convert between races.
More info about Roadsport series -> http://www.historicrace.fi/indexe.htm
I did drove only Drift season last summer, car was still little uncomplete and didnīt want to rush things.
Video footage from last Drifting season.
https://www.youtube.com/watch?v=uifl8TzdMYg
So at first "Project 2010"
This is how it was when i bought the car.
Specs
Engine:
-LS3 from GMPP
-Tatech engine management, no MAF. http://www.tatech.fi/index.php
-Lunati voodoo 65602 Cam, 227 / 238deg 0.50" lift. max 0.583 / 0.600"
-Lunati Gold Patriot double spring set
-Pacesetter 1 3/4" longtube headers
-3" dual exhaust, separate.
475whp / 660nm torque.
Drivetrain:
-Cluthmasters FX500 Clutch and their flywheel
- Tremec T56 from -98 f-body, will prep during winters with some goodies
-Original rearaxle with 3.72 ratio, posi diff and c-clip eliminators.
Body:
-Converted to looklike 70-73
-Fiberglass Front end, hood, doors, trunklid, bumbers
-Full cage, including g-braces extending to cage
-Fully stripped, seamwelded
-Subframe connectors
-Lexan windows except front screen.
Car weights 1305kg = 2870lb with full tank and w/o driver. Weight ratio is 50.5 / 49.5% with driver.
Front suspension:
-Some stiffer lowering springs?
-Bilstein Shocks
-Some stiffer sway bar?
-Bushings are polyurethane in lower arm and sway bar, and metal in upper arm.
-81 Z28 steering box and steering arms (spindle) are about 1.5" shorter and turned towards wheel to gain more steerin lock and eliminate ackerman.
-Wilwood superlite brake calibers with corvette 12" discs
-17x8 AR TT2 wheels ET0 with 1" spacers, Tyres Toyo Proxes R888 235/45-17
Rear:
-Leaf springs, some stiffer ones with iron bushings
-Rear sway bar
-Panhard bar
-S14 Nissans Coil-overs instead of shocks, with 50kg/cm springs.
-Wilwood dynalite brake calibers with corvette 12" discs
-18" wheels, lot of options, all BAD. Tyres from my sponsor, finnish CR-Renkaat, 245/40-18, pattern from Bridgestone RE71, rubber compound from Avon Semislicks
(Iīm sorry that project pics dont link properly to this forum, if anyone knows how its done, please advice me. Simple [img][/img dont work, you have to change pic url someway..]
Bodywork
Engine fitted, LS3 engine did sit IMO nicely in place with original LS3 vette oilpan, sits low and far back, nearly mid engined Gearbox tunnel had to be remanufactured. 4gen pacesetter exhaust manifolds did fit rather easy in place, little bending ang cutting but couple hours of labour.
In paintshop
About ready
Dynoresults
In use
http://s324.photobucket.com/albums/k...5052010012.flv
Will be posting updates when project moves along, i will be doing basically suspension and steering mods for next season, and brake upgrades for track racing. For steering i am going for rack, and need to get wheels to turn much more. Selfmade control arms and some other cars spindles are THE plan, maybe from MK4 Supra, would get some descent brakes for bonus then.
For rear iīm gonna ditch the leaf springs, somesord of 4-link setup is major plan, other option is some modern car IRS + diff. Iīm not afraid of little custom job or cutting the body. But iīm open suggestions about rear modifications.
Old 12-19-2010, 12:27 PM
Vince@Meanstreets's Avatar
Nice ride, interesting body to use too. Most drifters like bodies you can easily get replacement parts for but more power to you.
there's a couple closet drift guys in here but not to many.
Why not stick with the leafs. My understanding is you need a beefy rear suspension...ie type that doesn't bend easily and has has a relatively low roll center.
Either way you go please keep us updated.
Vince
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-19-2010, 12:34 PM
BBC69Camaro's Avatar
Nice car, great pics
Old 12-19-2010, 12:55 PM
Vince
I assume that i can get more traction with 4 links, would be lighter and most important easier to setup for different tracks, when leafspings own sprinrate and damping action mess coil-overs setup a bit. Alltough with IRS setup it would be better when entering normal track races.
Now i have few leafs removed from packs and coilovers with relatively soft springs, i can setup overall springrate to correct(ish) level thatway, changing springs to coilovers.
Leafsprings doesnīt make setting shock absorbers that easy, since they have their own ability to do that.
Roll center, i donīt understand much about that area.
And sorry if my english sucks a bit, iīm from Finland. Hope you understand all...
Bodyparts, those are relatively cheap comparing to Jap cars, many guys drive JDM cars in here, when you need something in those, it sucks. And iīve allways wanted to do these things litlle different than everyone else, makes also easier to get sponsors.
Old 12-19-2010, 02:36 PM
coolwelder62's Avatar
Nice car,look's like aton of fun.Keep posting.
Old 12-19-2010, 02:37 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Looks like a lot of fun. Welcome to Lateral-G.
Curtis
Old 12-19-2010, 03:35 PM
Got you, I forgot the detail that you wanted to use the car for different raing formats.
Checkout Heidts, they have a nice IRS system
Vince
Dealer for
NEVER FORGET -11
Old 12-20-2010, 01:50 AM
And letīs point this out yeat, handles quite well for such basic mods, or what do you say
Old 12-20-2010, 04:15 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Love that first shot.
My LS7 69 Camaro
Old 12-20-2010, 04:26 AM
For Early Camaro Spindle Conversion
# Combine these Steering Arms with an Early Camaro Spindle or our Drop Spindle and Remove up to 13 Additional pounds!
# Allows Excellent Bump Steer Adjustability.
So whit what spindles are these supposed to be used? 1gen or early 2gen?
