Old 02-02-2011, 04:39 PM
onevoice onevoice is offline
Blake
Is the upper arm the only one modified for more clearance, or is the lower arm different also? Is the lower arm only made for a coilover, or do you have a version for a regular spring?
James
Are you still running the Pozzi modified steering arms on the OLC? I was looking for the old post where you showed what was done, I found it but all the pictures are gone. Any chance you could link them again?
Old 02-02-2011, 04:56 PM
James OLC's Avatar
Yeah - we've still got the modified steering arms on the car with seemingly no issues to date. When we got back from one event last year (I think it was the UFO weekend at Reno-Fernely immortilized by Mary in this months issue of CP) some of the alignment specs seemed a bit out and we questioned whether we were putting too much stress on them at full lock against the steering stops but they appear to be fine. We'll probably mag them when we change over to the new spindles with ZR1 hubs just to be sure.
I'll see about restoring the pics - I have them, they just got shuffled when the directories changed after the last website update.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 02-02-2011, 09:37 PM
LM7_67 LM7_67 is offline
I am also using the high clearance arms with a stock subframe (and L&H Kustoms tall spindles). The subframe just needs a little clearance grinding on the UCA mount. I don't think I could run the 275s up front with out these arms.
I think the difference in sway bar mounting methods (and possibly some other things) makes the LCAs NOT interchangeable between stock and the SpeedTech subframes.
1967 Camaro - LM7, T56, TVS, 12.7:1
1996 Impala SS - DD
Old 02-02-2011, 09:59 PM
Blake Foster's Avatar
[QUOTE=barraza;330429]Blake
no the lower as well as the sway bar are also modified to give maximum clearance. the lower will only accept a coil over, we moved the coil lower mount outboard as far as possible to help with the motoin ratio also, gives the better better control.
Blake Foster
www.speedtechperformance.com
Old 02-02-2011, 10:02 PM
Originally Posted by MarkM66 View Post
What issue is there when trying to use them with a stock spindle?
The fact that there is no Droop/ bend in the arm and no upper bump stop means that there is a "Small Chance" the arm could come in contact with the frame when using a STOCK HEIGHT spindle under full extention.
Not to worry because we will not sell them unles you are also buying the TALL SPINDLE or the sub frame. Sorry.
Blake Foster
Old 02-06-2011, 12:42 PM
awr68's Avatar
awr68 awr68 is offline
Add me to the list of proud owners of the Speed Tech front sub with ATS tall spindles!
I have driven two Camaros with this setup and their rear suspension as well and totally loved the ride, handling, install and stance! And then there's the customer service...top notch!!
Tony
'68 Camaro
Old 02-06-2011, 10:43 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Huge vote for Speedtech anything----awesome people and great products---
Doug
Old 02-07-2011, 02:15 AM
ibdmann ibdmann is offline
I've got the speedtech sub. It's a nice piece. So it weighs 125 pounds, what does a stock sub weigh? Getting ready to install the old style sbc with a tko and a scatter shield. Will the manual linkage work or would a hydraulic clutch be prefered?
Old 02-07-2011, 09:54 AM
if you told us you were using the manual linkage when you ordered it then you would have received the Z bar bracket that attaches to the sub. if you need one let me know and we can send one to you No Charge, just shipping.
so either will work.
Blake Foster
