Old 07-18-2011, 06:57 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
Default 1st gen heater blower removal
Hey guys - does the right fender have to come off a first gen F body to access the blower motor?
We will be going to a Vintage Air - but for now need to slip the heater box back in. Front fenders, hood - etc are on - but we left the firewall blank for this reason.
I can't get the blower box with the blower motor to fit in. I haven't yet tried taking the blower motor off - but none the less it doesn't look promising.
Been there done it stories????????
Old 07-18-2011, 07:00 PM
Rybar's Avatar
Rybar Rybar is offline
This I would like to know as well.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 07-18-2011, 10:48 PM
67 LS1 Vert 67 LS1 Vert is offline
I really don't think it is possible at all. I have a 69 camaro apart right now and don't see how you can reach the bolts with the fenders on.
You will need access so you can install the cover plate so you might as well remove the fender. Make sure you use lots of tape on the edges for protection. Cheaper than paint.
Another tip is to bag and note all the bolts so you know where they go and make sure you tape the shims and note where they came from.
Old 07-19-2011, 09:38 AM
TT302Z28 TT302Z28 is offline
You can successfully do this by either removing the inner fender or loosen the fender and gentley pull it from the bottom to gain access.
Old 07-19-2011, 12:59 PM
Musclerodz's Avatar
remove inner fender or pull fender completely.
Mike Redpath
Musclerodz & Customz
facebook page
Old 07-19-2011, 02:39 PM
BBC69Camaro's Avatar
Inner fender method worked for me, but that thing was a pain getting back on and positioned properly. If I had to do again, I'd loosen the front clip, much easier imho than pulling the inner fender, just need to get one passenger's side fender loose enough to get at the hidden bolts.
