Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Roadster Shop Chassis and Components
Old 09-13-2011, 04:06 PM
RS-Chris's Avatar
RS-Chris RS-Chris is offline
Supporting Vendor
Default FAST TRACK '67-69 Camaro Chassis
Introducing our FAST TRACK chassis for '67-69 Camaro
This chassis system features a fully boxed frame design that greatly improves strength and rigidity over the factory unibody.
Frame Features:
  • RS Fast Track Front Suspension utilizing proprietary geometry
  • C6 Corvette spindle and Z06 hub assembly
  • Adjustable Afco billet coilovers
  • 1.25" splined front sway bar with C6 Corvette end links
  • Custom fabricated, fully boxed, 10 gage frame rails
  • Utilizes all stock body mounting locations, bumper and core support mounts
  • Lowered ride height
  • Engine mounts for SBC, BBC, or optional LS Motors
  • Custom center crossmember with adjustable, drop out trans mount
  • Mid brace crossmember with exhaust ports for up to 3" exhaust
  • HD Ford 9" housing with 31 spline axles
  • Large diameter triangulated 4-bar rear suspension
Pricing and info: http://www.roadstershop.com/products...amaro-chassis#
Old 09-13-2011, 05:15 PM
Sieg's Avatar
Sieg Sieg is offline
That raises the bar a bit.
Old 11-19-2011, 03:10 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
I have a question about this first will this work under a X-body car 72 Nova. Second I noticed the the upper control arms mount point are the same high as the the arm tabs. Are you not worried about fatigue on this point as it is a high stress area. I am just asking I coulf be wrong I sure you have raod tested the crap out of this this just curious.
Old 11-26-2011, 09:08 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Default How much more weight for a full frame?
I bought a car that already was on its way to a Chassis works frame replacement. And the replacement frame, G-link, and an LS engine will keep the car at the same weight, or even less. I thought about a replacement full frame like one of these before I bought the car I have now.
What is the weight effects of a replacement frame like this one? Looks like it would add weight, not a bunch, like maybe 200 lb.
Just asking...
DETONATOR - 69 Camaro RS
Old 11-29-2011, 08:31 AM
RS-Chris's Avatar
Supporting Vendor
Honestly, we have not put one under an x-body yet. We know many of the F-body structures are similar to the x, but without trying it first hand, we couldn't say for certain.
The area of the frame you were asking about is 1/4 inch plate both tied directly to the shock mount and the frame and on the other side has an 'I-beam' profile. It's incredibly solid!
[B][FONT="Arial"]WWW.ROADSTERSHOP.COM
Old 11-29-2011, 08:36 AM
RS-Chris's Avatar
Supporting Vendor
Just asking...
The weight gain is quite comparable to the average modifications performed on these vehicles i.e. removing the leaf springs, replacing the rear framerails, subframe connectors and subframe.
When you factor in removal and addition of these components, our chassis is fairly close weight wise, but with the added integrity of a single, continuous unit instead of 3 components tied together.
Old 11-29-2011, 04:52 PM
michael6372 michael6372 is offline
I have a question about this first will this work under a X-body car 72 Nova?
X2! I was wondering the same thing! Would be great if it fit into a 1970 Nova!!
Thank you
Michael
Michael Scheuren
www.streetmachinecentral.com
Old 12-03-2011, 11:27 AM
98ssnova's Avatar
Need a test car I have one that is sitting while Im am deployed and I would to try it out...
