07-30-2011, 03:45 PM
Finally a little progress !!!
08-28-2011, 11:02 AM
08-28-2011, 12:56 PM
Originally Posted by 69c4x11
If it sands easier, I will try it,, I ordered 2gal,, will order the G2 on the final blocks,, can you get it in gray ??Haven't looked yet !! Thanks Roger J
yes, it's available in gray as well
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
08-28-2011, 03:46 PM
Yes I got a gal of gray,, Sands like you said it would,,, Bought a cheap gun with a 2.5mm tip, it makes a difference,, G2 sands as easy as most 2k primers,, which I'm using to final block,,, thanks !! RJ
01-15-2012, 04:41 PM
Canned the Nova Dash,,
01-15-2012, 05:41 PM
Looking Good..
01-17-2012, 12:05 PM
Nice looking project!!!
I'm wanting to cut 3/4" out if the a-pillars on my 67 nova. How much work is involved and what do you run into that was unexpected?
01-18-2012, 01:24 PM
More than you would think !! Door latch is on outside of glass, this will have to be changed,, to move to inside of door because glass will run length of door, fuzzies will not work and no way of mounting then unless you make inner top of door removable so you can screw them in,,I'm using fuzzie's thar are wider because ,with the stainless trim gone the gap is wider, The door latch was the fun part, had a shaft with bushing made to go behind the glass channel. there is enough clearance to work with stock latch, you are going to need a long channel for the front of door ,so glass will be stable, you could use your old vent window channel,, If I can help ?? send phone # , Roger J
01-19-2012, 11:57 AM
Wow! Sounds a little confusing. Haha. I want to know more. I'll send you a pm.
02-10-2012, 01:29 PM
In process of welding up 57 Ford dash. drastic improvement !!Will post pics later,,
