Old 04-30-2012, 01:24 PM
makoshark makoshark is offline
FINALLY got the driver's side mini tub installed!!!!!!!
Old 04-30-2012, 02:35 PM
I have been researching driveline angles and am a bit still confused on exactly what I need to set my rearend and transmission angles at. I spoke with the company making my driveshaft and they told me they usually try to shoot for 2* down at the trans tailshaft and 0 to 1* down at the pinion. I am running Ridetech Airbar with coilovers at all 4's. What do I set them at?
Old 04-30-2012, 02:45 PM
Roberts68 Roberts68 is offline
Looks great!
Is there a bluish gray coating on the tubs or is that a camera deception?
I was wondering whose tubs you used as I have not followed your thread all along, then I saw you were going to split and widen the OE and thought NO WAY, that looked too good!
Read on to where you decided to use DSE.
Old 04-30-2012, 02:50 PM
Thanks...lol, I got lazy and just ordered a set The blueish grey your seeing is Dupont epoxy primer. My whole car is coated in it. I primed the tubs prior to installing them. Keeps them from flash rusting and helps already having them coated once installed.
Old 04-30-2012, 03:11 PM
Sonar Chief's Avatar
Nice Are you gonna stitch weld the inside to the trunk and pan?
Looks good, keep it up and you'll be done
Old 04-30-2012, 03:35 PM
Yeah, I have a bit of a gap where I cut out too much metal at the rear of the tub. I'll finish welding it all there once I get it up on the rotisserie. It's just plug welded at the moment. Just like the factory did it
Old 04-30-2012, 03:40 PM
I take that back, I forgot. I have to fill in a gap at the rear of the tub in the trunk and I'm going to use some Lord Fusor body adhesive instead of stitch welding it there.
Old 05-01-2012, 04:50 AM
Driveline angles! Any help?
Old 05-01-2012, 06:02 AM
Sieg's Avatar
Sieg Sieg is offline
Here ya go:
http://www.iedls.com/Education-Zone.asp?CID=6
http://www.hurst-drivelines.com/wp-c...roc_111606.pdf
Old 05-01-2012, 01:24 PM
Thanks Sieg
