Old 05-05-2006, 12:25 PM
Scotch Scotch is offline
Wow-
A little homework turned up some suprising numbers...suprising to me anyway.
LS2 engine- Approx. $7,500
GM Wiring Harness for LS2- $750
GM ECM for LS2- $1,500
Total mods:
AFR 205 heads (larger valves, double springs, Ti retainers)- $2,300
FAST 90mm intake- $870
COMP 230/232 114+12 cam- $350
21st Century Street Machine stepped race headers (already on engine)- $2,100
$15,370?
Am I close?
Dang.
~SP~
Old 05-05-2006, 01:17 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
You can get the LS2 for about $5500. Not sure what shipping would be though.
http://www.crateenginedepot.com/stor...61-P929C2.aspx
My guess after the mods; 525.
Old 05-05-2006, 01:36 PM
Diognes56's Avatar
Diognes56 Diognes56 is offline
Nice . I can't wait to see what it does with the mods, I am with the other guys 540-560 at the crank. This just makes me want one even more .
David
Old 05-05-2006, 07:26 PM
Steve1968LS2's Avatar
Originally Posted by Scotch
Wow-
Total mods:
$15,370?
Am I close?
Dang.
~SP~
No.. LS2 engine is only $5500
ECU and harness is not as expensive as you listed.. the cheapest route is to find a pull out LS2 with eletronics from a wrecked car..
Old 05-05-2006, 07:27 PM
Oh, by the way..
Corrected numbers on the last pull:
573 horsepower
505 ft. lbs. torque
Old 05-05-2006, 08:28 PM
Todds69's Avatar
Todds69 Todds69 is offline
Sweet!!! Oh by the way, I thought you were putting a LS7 in Penny? Or is this for something else, or maybe I am screwy in the head.
Old 05-05-2006, 09:22 PM
Datsbad's Avatar
Datsbad Datsbad is offline
damn i was close. is this SAE or STD corrected?
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 05-05-2006, 09:40 PM
Yes you were.. those are corrected, but the weather was good so the correction factor was low..
Ha.. no way GM was giving me an LS7.. I did write a story on a LS7 though..
Old 05-05-2006, 09:42 PM
Datsbad's Avatar
those are good numbers . I was going to say 570 and then went back and changed it to 560 .
thats cool . good bang for the buck !!
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 05-05-2006, 10:11 PM
slownova slownova is offline
what throttle body did you go with? stock? also what maf, or are you using speed density? good numbers. what did u use to tune it with?
