Old 03-15-2013, 01:55 PM
ls69bird's Avatar
ls69bird ls69bird is offline
I live in Macomb twp. What engine mounts & headers did you use?
Old 03-15-2013, 04:28 PM
CFster CFster is offline
67 here. Wouldn't change a thing. Link is in my sig.
'67 GTO - LS3, 4L60E, SC&C AFX Package, KORE3 C6 Z06, Boyds PT-09s
'67 GTO LS3 Swap
Old 03-15-2013, 05:34 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Lapeer here...
I built my own mounts and used Hedman Muscle Rod mid-length headers. I also used a f-body pan but notched my crossmember for clearance.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 03-15-2013, 08:13 PM
JB64CHEVELLE's Avatar
JB64CHEVELLE JB64CHEVELLE is offline
I have a 64 Chevelle and used street and performance mounts, Mast motorsports pan and notched the front crossmember. For a harness I went with Speartech and then used a Ricks tank. Good to see some more early Chevelles here.
1964 Chevelle SS,Ls1,T56,DSE 3 front&rear
1964 El Camino
1971 Chevelle SS
1971 Camaro
Old 03-15-2013, 10:48 PM
Hi JB,
Do you have any pictures on the notch and reasoning behind it? Im going to be assisting a member with a swap and want to get more info on different set ups.
Old 03-16-2013, 09:23 AM
65_LS1_T56's Avatar
I'd be interested in how JB did his too. I can say that the earlier A-bodies (64-67) are a bit tighter around the front crossmember. The later frames had more of a flat area on the back and top side for pan clearance, the early ones are more of a "v" if that makes sense. I went with the F car pan, well for one I had one, and second it's shallow on the pickup side for ground clearance, and has pretty decent inner tie rod clearance. The biggest reason I notched mine was to get some clearance between the back of the passenger side cylinder head and the firewall. Some guys notch the oil pan instead for the same result.
Here's a couple pics of my notch:
Aaron
65 Chevelle
Project G-Velle
Project G-Vette
Old 03-16-2013, 10:30 AM
ls69bird's Avatar
Nice job on notching that frame.
Old 03-16-2013, 06:23 PM
Hi Vince and Aaron, I will post up some pics for you on this. I had to notch the frame for oil pan clearance with the Mast pan. You will also need to check tie rod to oil pan clearance. I Left just enough room from cylinder to firewall for my coil packs. If your not putting the coil packs on the back of the head and making your own mounts you probably can move the motor back far enough to clear the crossmember. You will also need to modify the firewall to have access to the bellhousing bolts. I have a T56 and ended up cutting the complete trans tunnel out and made a raised one front to back . This was so I could have a low stance, driveshaft clearance with the T56. Hope this makes sense.
1964 El Camino
1971 Chevelle SS
1971 Camaro
