Old 08-18-2013, 09:25 AM
DRJDVM's '69's Avatar
KISS...keep it simple stupid..
So then the debate comes back to, which side to run the switch.... my understanding is that it really depends on what your goal is.
If the goal is to cut all power in the event of a crash etc, so none of the electrical systems have juice flowing through them, then it should be close to the BAT and on the positive side. If you crash and things are all mangled, you may have created new ground points all over the place with shorted wires...and you don't want a bunch of hot circuits anymore
If the goal is more to be able to just essentially disconnect your BAT when the car is sitting, so the BAT does constantly get drained, then just put it on the NEG side
Old 08-18-2013, 11:26 AM
As for the negative being switched, couldn't the starter get a dead short and cause a fire if it the positive was hot ??
Old 08-18-2013, 08:32 PM
Lenie's Avatar
Lenie Lenie is offline
Disconnected from kill switch straight to battery, nothing. Decided to rewire back to original set up straight from 1 wire alternator to starter, still nothing. I believe I've done something to fry my msd 6al 6420 ignition box (must of spiked it)...no fuse..really...crap. Guess I'll buy another....hmmm cars
Lenie
Old 08-18-2013, 11:21 PM
What would Greg Weld say That's hot rodding! Still hurts though doesn't it.
I hope you get it figured out.
Old 08-19-2013, 12:10 AM
Lenie's Avatar
Ya just like Greg, trying to make this hobby fun!
Lenie
Old 08-30-2013, 10:59 PM
Lenie's Avatar
Took the long road there but got er' fixed!
Lenie
Old 08-31-2013, 06:26 AM
Spill your guts matey!
Did ya LEARN something along the way -- because that's the best part of screwing something up is if you "get it" when you're done?
XOXO
Greg
Old 08-31-2013, 09:58 AM
Lenie's Avatar
Ya Greg, everything I do on this car I learn something new and lovin' it. A little embarrassing, probably should have been the first place to look but it was my last, you know spark, air and gas. I was changing to a bigger alternator wire to a kill switch so after I was done and it didn't start, I thought it was electrical, something I screwed up and got it stuck in my head that was the problem. I started by buying a new battery, then put everything back the way it was, didn't work, moved the ground to the kill switch instead of positive, didn't work, installed a new coil, didn't work, installed a new msd 6al box didn't work, redid all my grounds, didn't work, keep in mind I've only driven this thing about 5 miles, put a volt meter to the distributor and it checked out fine, checked everything for spark and all was good, pretty puzzled at this time and reading everything on google there was about msd issues. Got to talking to one of our mechanics at work and he says Lenie, I know you haven't driven the car much but it comes down to spark, air and gas....put a new cap and rotor on and change out the spark plugs while your at it and see what happens.....so I changed them out and bingo, starts up the first time she turns over. Funny how the mind works when you get stuck on something and don't look at the big picture... live and learn. Car goes to the upholstery shop first week of October, said they'd have it about 10 days and be done. I missed the summer but finally the car will be pretty much finished
Lenie
Old 08-31-2013, 06:29 PM
Lenie Don't feel bad I usually take the round about way to get things figured out too. Glad you fixed it and its going to the interior shop.
It won't be long now !
Old 08-31-2013, 08:10 PM
Ron in SoCal's Avatar
Lenie please don't feel bad. I go through this crap all the time! Latest project f-up was a fuel issue on my boat. Two fuel pumps, a fuel pump push rod, fuel log return valve and a redo of the tank pick up I finally replaced the non-ptfe return line. Dog fired right up.
Us non-pros learn a lesson each time we open the tool box. Fun huh?
Ron in SoCal
69 Camaro in progress
