Old 07-13-2014, 09:34 PM
Originally Posted by 57hemicuda View Post
That is what I mean Greg, you get used to wrong, so when you make it right, that seems wrong. I still have a bunch of crap to do on this car before Michigan, so it will be a thrash to get it done. I seriously can't wait to try it out.
That's where SUTTON is worth his weight in gold -- and he's not svelte! LOL
He talks to me before I go out - and reminds me to sneak up on things - and that helps! Just having someone there to calm you down - talk some of the adrenalin off... The car gets better because he knows what to do when I tell him it's doing "X" --- and he makes my driving better because he keeps me back from the ledge. HAHAHAHAHA It's true though!
Old 07-14-2014, 05:38 PM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
Got the masters in place, will make up the lines tomorrow. This is getting stupid working on two cars at once, and posting crap.
Old 07-14-2014, 06:25 PM
Krazed Krazed is offline
Hang in there Ron!
You're an inspiration to all of us! I for one know that your build is inspiring my next one entirely!
'68 WideBody Mustang Coupe in the works.
RoadRace taste on a Craigslist budget!
- Travis
Old 07-14-2014, 08:45 PM
Track Junky's Avatar
Looking good. Curious to see the difference in brake pressures.
Gaetano Cosentino
Old 07-15-2014, 03:29 AM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
You need to hire a cute marketing/social media girl so you can stay focused...on the "working on cars part"
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 07-15-2014, 05:33 AM
Payton King's Avatar
Very Racy! You might be fast with brakes on both the front and the rear. LOL
Old 07-15-2014, 07:27 AM
dontlifttoshift's Avatar
Ron, which inner seals were you running before? What is the surface finish on your axles?
There are not awesome billet seals for 35 spline so I just put these in Rich's car. Allstar number 72098
http://allstarperformance.com/product.htm?prod=747
We weren't having a problem, It just really upped the maintenance routine knowing the gear lube washed the grease off the bearings. The more I thought about it, gear lube is plenty good for the bearings but the unknown was how much lube are we getting there. USCA in St Louis and the Motorstate....we'll see how it goes.
Donny
Old 07-15-2014, 01:58 PM
57hemicuda's Avatar
I was running the billet style aluminum housing with a single style seal that Moser provides. Moser doesn't do much on the finish of those axles, so I called Speedway got the O.D. that the axle should be at the seal surface. Took it to a machine shop and polished it on a crank polisher to that O.D.
Old 07-16-2014, 03:02 PM
57hemicuda's Avatar
Looks like the new setup works pretty well, at least pressure wise, haven't driven it yet. I seem to be able to adjust the pressures between 1200psi front and 800psi rear, and then opposite that, by adjusting the balance bar. I bought a 7/8 master just in case for the front, I may install it after driving it, but at least I'm close. Can't wait to see if it feels different.
Old 07-16-2014, 03:51 PM
Ron in SoCal's Avatar
Ron are you running 6Ps? If so, what size masters? I'll have to check, but I think Baer spec'd 3/4" front and 15/16" rear (14" rotors).
Ron in SoCal
69 Camaro in progress
