Old 06-23-2014, 10:08 AM
Windsor GTO's Avatar
Windsor GTO Windsor GTO is offline
Default Pictures of Block and Supercharger
See the new block and the supercharger
Old 06-24-2014, 07:27 AM
Evan Iroc-Z Evan Iroc-Z is offline
Those ladder bars are HILARIOUS!!! That is really going to throw people for a loop.
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 06-24-2014, 07:46 PM
x2 I like that wood covering.
That's a monster blower.
Old 06-26-2014, 07:55 AM
Default Thanks
Yeah I really thought it would be funny watching the NHRA tech look under the car and BAM! Broom stick?
The blower is a Procharger F1X with a front mount bracket. The radiator will be horizontially(more of an angle actually) mounted with a dual blow thru fan set-up.
The new engine is a Dart Iron eagle filled with Callies Crank, Oliver Billet Rods, Racetec pistons and a Danny Bee belt drive.
Old 07-23-2014, 05:46 AM
Default Sheetmetal
Well finally got enough spare time to start the interior sheetmetal. Made both tubs last night. They are freaking huge but it allows me to slam the car low and not worry about tire growth or shake. ended up 44' front to back with an average width of 23". First time making them so it was pretty cool. Once everything is fitted it all goes out for hydrocoating.
Old 07-23-2014, 07:49 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
All I see is a big blur. C'mon bro...we need better pics.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 07-23-2014, 12:55 PM
Default LOL, I will get some better ones tonight
Less beer more pictures
Old 07-23-2014, 04:37 PM
Default Better pics
Mcilwaine actually got them both installed today so here they are.
Old 08-14-2014, 12:17 PM
Default Sheetmetal in
Sheetmetal is in and getting ready to paint the rollbar then rivet. Core support is being cut out as well to make room for the supercharger.
Old 09-17-2014, 06:35 PM
Default update on build
Well the tin is about finished and the front is about a week out from completion. Small details are killing the time.
