Closed Thread
Old 01-05-2015, 03:37 PM
A couple of things people will want to see if you have them... Cam details and a dyno sheet? Do the heads have any porting work done to them other than the standard AFR ports?
GLWS!
No cam specs, the engine builder held those close to his chest. I believe the grind was in the .600 lift range and 240/244 @ .050, on a 110 lsa. But the exact specs are unknown. Heads are full CNC as far as I could tell.
It was his 525 rwhp package, at least in a late model F body or Vette. Might be slightly less in our older cars.
Old 01-05-2015, 04:40 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
This was listed on 10-25-2006 for $8500. Just a little reference.
http://www.corvetteforum.com/forums/...k-forsale.html
Curtis
Old 01-05-2015, 05:54 PM
Che70velle's Avatar
Great price here guys. Anyone in the market for an engine will appreciate this price.
Thanks Dad!!
Old 01-05-2015, 09:15 PM
Nativefx Nativefx is offline
Given that it's a stroked LS2, what kind of tq numbers are you expecting and at what rpm range? How long ago was it completed and is it basically a long block (no harness, accesories, etc)?
Is there enough vacuum for power brakes?
thanks
Old 01-06-2015, 07:17 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
thanks
In similar engines I see approx 450 at around 3000 and no issues with vacuum booster.
Needs Intake, rails, injectors, TB, coils and front acc. I have stock LS2 rockers and stands but no pushrods.
Will ship for FREE to lower 48
Old 01-09-2015, 08:17 AM
Corey R. Corey R. is offline
Pm Sent.
-Corey
Old 01-09-2015, 03:05 PM
Vega$69's Avatar
Deposit Received
Old 01-09-2015, 03:18 PM
califconstruct's Avatar
califconstruct califconstruct is offline
I can honestly say, that pricing had me thinkin' about it!.
Old 01-10-2015, 09:46 AM
jwcarguy jwcarguy is offline
Banned
Guess that you won't be needing the set of hardened 7.400" .080" pushrods and full set of LS2 rockers and stands that I pulled out for you early this week??
Jeff
Closed Thread
