Old 06-05-2015, 05:20 PM
Sonar Chief's Avatar
Post
Originally Posted by paulk68 View Post
How does the AMD glass look and fit are you happy with it?
I haven't picked up the glass yet ... the AMD rep used their glass on his Duster, said it fit well!
Originally Posted by LanceL View Post
Thanks for those two pics. That was the before correct? Do you have any pics that show what it looks like after? Do I make holes and "spot" weld it or tack it in all the way across and then grind down? I'm sorry for the ignorance on this one? I'm just not sure how to move forward because my dash was already pulled apart and I cant tell how it was together?
No problem ... in the first pic you can see where the 2" band of rust goes across the cowl, that is where the upper dash came to and I just drilled out the spot welds to remove that strip. I will use my hole punch to prep the upper dash for spot welding.
I need to fit the front glass to make sure the angle at the bottom is in-line with the A pillars when the glass is set inside the opening ... I may have to sharpen the or change the angle to match the A pillar.
Michael
