Old 08-26-2015, 03:11 PM
dontlifttoshift's Avatar
I assumed remote reservoir.
You should be good to go.....I'm leaning towards pump at this point.
Donny
Old 08-26-2015, 04:25 PM
Musclerodz's Avatar
Originally Posted by Grnova View Post
Vince, I am running a Sweet Mfg. pump
Open flow 3.0 gpm
Flow @ 600 psi 3.2 gpm
Max flow is 1030psi
Good point if it matches the DSE rack I do not know?
Does the fluid look foamy and its starts making noise? And is the noise all the time or only after the car warms up. DSE rack only needs 2 gpm and use a flow reducer, but that should not cause a noisy pump.
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-26-2015, 05:30 PM
Grnova's Avatar
Grnova Grnova is offline
No the fluid is not foamy after I run it for 10 minutes it starts to make noise.
Interesting point about the rack. How do I know if I have a reducer is it the DSE fitting?
Tim
Old 08-27-2015, 05:19 PM
http://www.detroitspeed.com/Steering...rol-valve.html
we had a similar issue. looked like strawberry milk shake before we added it.
Old 08-28-2015, 08:31 AM
Grnova's Avatar
I have one of those installed, can anyone reccommed a pump?
Tim
Old 08-28-2015, 08:40 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Call Junior at Turn One
Old 09-01-2015, 05:47 PM
Grnova's Avatar
Tried calling turn one for a week now anyone know of a turn one vender?
Or another recommendation?
Tim
Old 09-02-2015, 10:59 AM
Try Chris Alston.
Old 09-02-2015, 11:23 AM
Blake Foster's Avatar
Donny I have a Billet Specialities resevoir...and no -6 is run for every PS line.
THAT IS YOUR PROBLEM!!! they have no baffels buy the Sweet res and your problem will be GONE.
Blake Foster
www.speedtechperformance.com
Old 09-02-2015, 11:24 AM
talk to Sweet they should have the best pump on the market. we are starting to use them on all our stuff now. they supply 70% of the nascar teams I am told
Blake Foster
