Old 11-03-2015, 12:00 PM
Swain's Avatar
Swain Swain is offline
Default Hydraulic Clutch
So I have a T56 6 Speed in my Camaro with a LS3
The clutch is pretty stiff and when you let it out ig really doesn't give you any feathering. It just kinda grabs. Is that fairly common with this type of throw out bearing?
Seems like the throw is pretty short. Tilton Master with T56 TO Bearing
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 11-03-2015, 12:43 PM
Rod P's Avatar
Rod P Rod P is offline
sounds like the TO bearing is too far away from the clutch teeth....that is how the bearings act when at the end of there throw....put spacers behind the bearing....the bearing is designed to have only 1/2 of premium operational throw(were it works and feels best) the bearing its self should should be about an 1/8th inch (0.125 thousands of an inch) from the clutch fingers
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 11-03-2015, 01:36 PM
Swain's Avatar
It mounts to the mid plate I think. Does someone sell spacers for that?
Jason Swain
Old 11-03-2015, 01:38 PM
carbuff's Avatar
carbuff carbuff is offline
Did you adjust the point which the pushrod mounts to the clutch pedal? I think they are somewhat sensitive to the ratio of the pedal...
Old 11-03-2015, 01:48 PM
Swain's Avatar
Did you adjust the point which the push rod mounts to the clutch pedal? I think they are somewhat sensitive to the ratio of the pedal...
That's another thing I was thinking about
Jason Swain
Old 11-03-2015, 02:00 PM
gerno's Avatar
gerno gerno is offline
What Bryan said. I've been fighting the pedal ratio myself. Even 1/4" can make a huge difference in feel, trust me. Another thing to help could be changing your line since if you are using AN lines but changing the pedal ratio is where I'd look first.
Old 11-03-2015, 02:38 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Thirded on the pedal ratio. I have the same master and t/o bearing on an LS7 clutch. When I switched from the Fbody GM master to the Tilton the clutch felt like an on/off switch. Double checking everything I realized I aligned it to the incorrect hole and once I fixed that it felt like a normal clutch again. Albeit with shorter throw than the GM master.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 11-03-2015, 02:58 PM
Swain's Avatar
sweet I have the same Clutch also. Do you know how much lower you went?
Jason Swain
Old 11-04-2015, 07:14 AM
Rod P's Avatar
the spacers stack behind the throwout....here is a pic there are a few companies that make them...I think all the conversion companies do
Rod Prouty
Bangshift Stories
Old 11-04-2015, 01:25 PM
How much lower what? The hole on the pedal arm or the pedal itself from shorter throw?
