Old 02-08-2016, 08:48 AM
pro66tour's Avatar
pro66tour pro66tour is offline
Originally Posted by 64G-lark View Post
Nice looking car Joe . I will have to follow you post.
Thanks Mark! finally had some time to read through your build, must say I've always had a soft spot for Larks. Coming along very nicely! I see you've been spending some time with Tom! Great guy, build and story! I've gotten a lot of info and inspiration form his '66. Was lucky enough to see it in person several times in Columbus. Be checking in when I can...
Old 02-22-2016, 12:30 PM
rocket66 rocket66 is offline
Great build, in the middle of my own '66 project. Did you use the BRP oil pan as well?
Old 02-22-2016, 06:44 PM
pro66tour's Avatar
Thanks pal...
Unfortunately the LH8 known as the hot rod pan hangs below the cross member by 2.5-3 inches. Lowered car, not good! Sold it local and went with a Holley LS 302-1. Clears steering at full lock and flush with the cross member. Hope that helps...
Old 02-23-2016, 03:36 PM
Originally Posted by pro66tour View Post
Thanks pal...
Unfortunately the LH8 known as the hot rod pan hangs below the cross member by 2.5-3 inches. Lowered car, not good! Sold it local and went with a Holley LS 302-1. Clears steering at full lock and almost flush with the cross member. Hope that helps...
Thanks Joe, that is very helpful! Keep up the good work!
Old 02-24-2016, 07:57 AM
pro66tour's Avatar
You too...
Old 04-02-2016, 05:18 PM
grendel grendel is offline
I'll keep you in my prayers. My brother had one done 8 years ago at 40.
Is this the car you're thinking of my headers for?
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 04-03-2016, 07:32 AM
pro66tour's Avatar
Many thanks John! Yes pal, that would be me. I need the headers to run parallel on either side of the trans as is most common. From what I gather these are aligned to have the exhaust curl in/up under the trans, inside the tunnel as the Vette application requires. I've been wrong before though. They are an outstanding set of headers...
