Old 03-15-2016, 04:42 PM
wiedemab's Avatar
wiedemab wiedemab is offline
Originally Posted by no go nova View Post
You wouldn't mind making another Trans tunnel😉?
Give B&B a call - - he'll sell you a trans tunnel. They are really nice!
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-22-2016, 08:10 PM
wiedemab's Avatar
Default A few days off work = Progress
The following progress is the result of 4 straight days of working in the garage and sleeping very little. I loved every minute of it!
Started off by working on the exhaust. 3" round to oval, then back to round at the muffler. Borla Pro-XS mufflers. I only ran it back to the muffler and plan to finish out the over the axle pipes and tail pipes later. I thought it would be easier to build it back to the axle before I put the floors in.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-22-2016, 08:14 PM
wiedemab's Avatar
Nice and tucked up - - - all worth the 2X cost of the oval tubing!
All tacked together.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-22-2016, 08:17 PM
wiedemab's Avatar
Default Seats mounted
I also got the seats mounted..... I bought threaded tubes and made "stand-offs" for the tracks to bolt to. Between the side mounts and the tracks, I have all kinds of adjustment. The seats bolt directly into the rectangular tubing crossmembers that I built.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-22-2016, 08:23 PM
wiedemab's Avatar
Default Front Cage Tube
I wanted the cage to fit up tight...........so, I ended up having to remove the front roof structure to weld it. Drill all of the spot welds out of the roof structure (after taking a few measurement of course!). Welded the cage bars and then replaced the structure. BTW -- - My interior guy will probably kill me. The headliner is going to be a tight fit.
Putting it back together.
Test fitting the roof skin.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-22-2016, 08:26 PM
wiedemab's Avatar
Default Roof - inner structure
I cleaned up the inner structure and brushed on a KBS products (kind of like POR15. - - it worked out pretty nicely.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-22-2016, 08:27 PM
wiedemab's Avatar
Default More Tools
I picked up this Mittler Bros bench top press and a dimple die set too!
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-22-2016, 08:35 PM
wiedemab's Avatar
Default After a detour to go pick up the press and dies......
We worked on the trans tunnel. I bought the front section of the tunnel from B&B. The rear section Dad and I formed with a piece of 4" steel pipe and a board that Dad shaped for a makeshift hammer form - - - I'm really pleased with how it turned out.
Made one section of the floor panel - - got to play with my Mittler Bros bead roller!
Welds ground and stitch welded into the rocker tubing (my added 3X5" tubing)
Almost looks like I know what I'm doing.
Botom view.
That was about all dad and I could squeeze into the last few days - - --
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-22-2016, 11:56 PM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
Is anyone else having a problem seeing your pics or is it just me? All I see is an X.
Jose
Old 03-23-2016, 04:52 AM
wiedemab's Avatar
Hmmmmm....... I'll have to mess with it. I'm trying to use Google Plus to size them to a normal size. The album is shared publicly, but Google changes things so often.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
