Old 06-20-2016, 08:50 AM
SSLance's Avatar
SSLance SSLance is offline
If you must have the forward upper cage bars, I'd just work extra diligently about tucking them as high and tight as possible. And pad them with the good stuff. The Finch and Tucker 2nd Gen Camaros both have full cages in them that you almost can't see they are so tight, same with the Viking Shocks F Body... Then set the seats as low as you possibly can.
Street driving with a 5 point harness sucks, there is no doubt about it. I tried it once and bailed on the idea. I imagine it would be even worse with a containment seat, between not being able to move at all plus not being able to see to the sides or the rear...that just isn't any fun (or safe) at all to me.
Your car didn't come with factory shoulder harnesses right? If there was any way to graft a set of factory style 3 point belts into your car, I'd seriously look into it (if they will work with your seats that is).
Otherwise, it sounds like you are going to end up with a race car with license plates...that you have to suit up and strap completely into for that trip to the grocery store. Not completely track restrictive but not the most fun street adaptive either. Just be safe mixing components.
Lance
