Old 09-23-2019, 10:46 AM
Kwag Kwag is offline
Why so much hate for the 600?
I'm actually interested as I had planned to use it in my build. Is it just the older ones?
Old 09-23-2019, 03:27 PM
If you are gonna run them hard (on the track mostly) there are much better solutions and the high rpm WOT shifting is a known issue for many.
If you are just cruising around on the streets and back roads, it's likely okay.
I had a TKO 600 many years back..... didn't have it for long but did not like the way it shifted or felt.
The Following User Says Thank You to Flash68 For This Useful Post:
Kwag (09-24-2019)
