As you saw in the previous videos - we still had a fuel pressure drop. This turned out to be even a bigger problem then I thought it would be.
Tuns out - I fried the battery cable between the alternator and the starter - so in this video I replace the wiire, install a 270 amp alternator, and install a Zero gauge wire between the new alternator and the fuse box.
After we fixed up the electrical system - I made the decision to replace the entire fuel system. I was sick of the external single pump design - and the leaking fitting/line problems that I kept running into.
So I picked up an Holley dual fuel pump kit + AFPR and return line from A&A Corvettes.
We managed to kill the battery trying to test fire the car (I forgot to put the fuel pump relay back in) - and so I had to send that off to get replaced.
After the battery came back - we primed the fuel pumps - and test fired the car!
