Old 02-18-2013, 01:06 PM
The Concept One LS9 set up works great!
http://www.lsxtv.com/news/ls9-powere...ley-treatment/
Mark
But are you going to use it ? I noticed you cut the frame allready and with concept one its not needed?
63 Z06
Old 02-18-2013, 06:01 PM
Stielow's Avatar
Stielow Stielow is offline
Yes I did use it on Mayhem and plan to use it on XV. They say you can use it with DSE mounts. Maybe with DSE base LS mounts that has the engine farther forward. With DSE LS7 engine mounts the A/C crashes into the sub frame. So for a few hours work we set the engine back 3/4 of an inch. Give them a call and see which DSE mounts it works with. I need the space so I have my engine back as far as it will go.
Originally Posted by cantcatchmitch View Post
mark, ive been paying alot of attention to your builds with the ls9s, im building a 66 nova with a lsa so alot of your info crosses over pretty well. one thing ive been looking to find out is how big of a reservoir you run for the supercharger coolant? i havent found anything on it and i figure you would be the guy to ask. thank you for sharing your wealth of knowledge with us, your builds are amazing to watch!
On the reservoir I’ve done it a couple ways. One is for a fill point and a air trap. To make your life easier make the fill point the highest point in the engine bay. If you can make it so any trapped air accumulates there. On Mayhem I did a fill/ reservoir/ air water separator. I made a 1 gallon tank that feed the intercooler pump. It was a tall tank that also was the fill point and had space at the top to be a air accumulation point. It worked great. A reservoir (or extra coolant) just adds capacitance to the system. If you have space it helps keep the temps more stable.
Mark
Old 02-18-2013, 06:39 PM
Stielow's Avatar
I quick note on how I modified the Anvil mirrors. You need to use the internals from a 2nd Gen Camaro mirrors. I don't like the cable operated drivers side mirror so I make my own mount using a stud ball from McMaster Carr and make a few small parts.
I also had to make mount to bond to the mirrors to mount the mirrors to the doors.
Old 02-18-2013, 07:55 PM
cmraman's Avatar
cmraman cmraman is offline
Looks Awesome!!
Robert McGaffin
McGaffin Digital Photo
http://www.flickr.com/photos/rkmphot...7594214498126/
Old 02-18-2013, 08:27 PM
coolwelder62's Avatar
Very nice.I love McMaster-Carr.They have everything to build a cool P-T car but DSE product's.
Old 02-20-2013, 11:48 PM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Pretty sure there's a market to have these bit mass produced Mark! I'd love to eliminate the cable on my driver's side mirror! Tight work!
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 02-21-2013, 04:38 AM
Z06Joe Z06Joe is offline
Another awesome build Mark!!!!! Definitely subscribing!!!
Old 02-21-2013, 07:03 AM
Kenny Kenny is offline
Originally Posted by CarlC View Post
I have an oil over-cooing condition for street duty. Even with a Mocal 202* thermostat the oil does well to get up to the water temp (160*). On cold days the needle usually does not budge off the lowest reading of 140*.
That oil temp is surely too cool. This makes a very good point though. You could downsize the oil cooler, at the same time, you aren't adding that thermal load to your cooling system. I would guess that you don't have piston squirters.....
I don't want to take over this thread with a bunch of technical talk, but am very interested in continuing the conversation....I'll start, or find another cooling thread somewhere else later
Old 03-10-2013, 07:29 PM
next69 next69 is offline
Mark, Do you have any updates for us? After seeing Mayhem yesterday at Autorama you are going to be hard pressed to raise the bar again.
Old 03-12-2013, 09:10 AM
468Camaro's Avatar
468Camaro 468Camaro is offline
Awesome thread ! I need my Jaw wired shut now...
Bowtie Nutt 68 Camaro Pro-Street 2x3 Ladder bar -backhalf 32x14 Dana 60 5.38, 406" 12-1. .Chet Herbert Billet Roller .645" 106' .Brodix Trk1, 830" Annular,Victor.glide-brake.. Needs Real windows.. 1989 Vette Z-51 357" 4bolt Forged, Dart IIS,Comp cam..Billet Specialties, 86" Iroc-z 468-400 ,2003 Roadstar 102" ..
