Old 08-12-2014, 01:47 PM
bentfab's Avatar
bentfab bentfab is offline
I also hammed out all the brake lines for the ABS system over the last week. Just for referance these brake lines took me a full week to make and I've done this twice before. 40 feet of brake lines. But doing it with out the front clip is a huge time saver.
HAHA !!!
I think I know what you mean... Looks killer !
Mark
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 08-12-2014, 07:11 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by bentfab View Post
HAHA !!!
Mark
Thanks. I think it is OCD issue. Doing hard lines.
Old 08-29-2014, 08:35 AM
Stielow's Avatar
Default Fuel Tanks
Ricks made me a very nice tank with twin Camaro ZL-1 pumps.
Vapor Worx preressure feedback sensor and TechAFX lines
Old 08-29-2014, 08:38 AM
Swain's Avatar
Swain Swain is offline
Very nice Mark.
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 08-29-2014, 08:42 AM
Stielow's Avatar
Default Clutch
I went with a Centerforce Clutch and D &D Performance in Wixon Mi installed a oil pump in my trans. They are offering this now. It is the same pump as the TR6060 in a Magnum box. I will use it to pump my trans fluid to the rad to cool the fluid then that fluid will go to the diff.
This a GT500 throw out bearing with a quick connect. The GT500 CSC has more travel and a smaller effective piston area so it will stroke farther.
Diff cooler
I installed the engine, trans, rear axle, drive shaft and fuel tank last weekend.
Also you can see the Bosch ABS controller in this shot in front of the engine. Late change to go to Bosch to work with the Carbon Ceramic Brakes
Old 08-29-2014, 08:55 AM
Stielow's Avatar
Old 08-29-2014, 08:58 AM
Sieg's Avatar
Sieg Sieg is offline
Progress!
Old 08-29-2014, 09:07 AM
Track Junky's Avatar
Lord!! The Insanity!! This car is going to be insane!!
Gaetano Cosentino
Old 08-29-2014, 09:59 AM
MeanMike MeanMike is offline
Interesting. I love how you use so many factory parts. How do you bleed the system?
Old 08-29-2014, 10:49 AM
bentfab's Avatar
Hey Mark,
Can you clear some room in your PM box.
Mark
