Old 02-02-2007, 12:52 PM
68protouring454's Avatar
lol, its on, 50 says its 660-680, winner pays up at rth3
Old 02-02-2007, 07:42 PM
TravisB TravisB is offline
Originally Posted by 68protouring454
cool, check out chevelles.com for some great combos
i went 11-1 496
scat 4340 crank, scat h beam 6.385 rods, wiseco pistons
afr 315 cnc heads, ultradyne 4/7 swap cam, .711, 262,266 dur @.50, solid roller
dart intake, pro systems hp1000 built carb
canton road race modified pan
been ready to dyno for months, should be 660-680
goodluck
Doesn't this have a new home........?
Kenny Davis Hot Rods
Old 02-03-2007, 05:18 AM
lmao??????????
Old 02-03-2007, 11:26 AM
I don't know you guys, but I would like to get in on the betting.
I'd put up $50 on the it hitting over 660 easily. Lingenfelter did a 9:1 502 buildup over 10 years ago very similar to this and hit did 663 hp. Cam specs are nearly identical, but your AFRs gotta be better than the oval ports he was using.
Of course, that was the legendary John Lingenfelter.
Old 02-03-2007, 07:07 PM
fesler's Avatar
fesler fesler is offline
Originally Posted by Streetking
How about you sell me that weak 427 you have and put your new TT motor in early..
This car is not a car I built from scratch like the others, I just thought, while he's got it apart, I might as well upgrade the motor. I would have to get another subframe or modify the stock one to accept a LS series motor. I really need to decide if I want to go BB or SB..
fesler, you have built some killer cars and I understand where your coming from, but your cars are in a different league than my '71. Here is a picture of my 1400hp hot rod, it's insane..
thanks everybody for your input,
SW
Thanks for the props man but they all start somewhere and we are buildng a 70 Camaro right now with a build ZZ4. The customer just wants a mild engine. That Viper is sick and I bet its wild to drive, same thing we are doing to a 69 Camaro right now I will post pics soon. Let me know if you ever need anything.
Chris Fesler
Fesler Built - Scottsdale, AZ
Old 03-07-2007, 09:23 PM
nvawgn's Avatar
nvawgn nvawgn is offline
Is The Motor Done?
Old 03-13-2007, 11:50 PM
BLT2DRIVE's Avatar
BLT2DRIVE BLT2DRIVE is offline
Smile Engine choices
How about 301 105 HP smog motor. That 'll make Autocrossing a challenge?
