Old 11-21-2008, 06:24 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Originally Posted by Apogee View Post
There's a company that makes really nice large gauge wire called "Arctic Ultraflex Blue" made by Polar Wire (http://www.polarwire.com/) that uses higher quantities of smaller strand wire and a special jacket to make remarkably flexible wire given it's size. It makes routing much easier and the stuff is really nice to work with if not a bit spendy. I learned about it when researching a rear mounted winch my my early Bronco.
Tobin
Did you buy 100' of it? I don't see smaller lengths.
Old 11-21-2008, 07:23 AM
I used the DSE cables.....very high quality and small strand. Seem plenty flexible. Last place to cut corners is on battery cables. Especially when you are running them the length of the car.
Old 11-21-2008, 07:27 AM
deuce_454's Avatar
i got a small roll from a guy that works on the railroad... the diameter of teh copper is atleast 1/2 inch!! and the quality is top notch... welding ground wier also works great, and can be found cheap on metal scrap yards.. i buy it by the pound for the going rate of the copper scrap
Jake: Hit it.
Old 11-21-2008, 08:15 AM
parsonsj parsonsj is offline
And especially if you have pull the carpet out to get to them!
jp
John Parsons
Old 12-17-2008, 08:09 AM
JETSET700's Avatar
JETSET700 JETSET700 is offline
Default Cables
Grounded to engine here too. Especially on a modern engine with FI &
ignition controls. Mine is 01 fine strand in car to a proper bulkhead connector.
(a must) & the ground is strap bolted through trunk to 01 routed along framerail into trans tunnel to back of head.
My + is in the sill just like tail light harness on the driver side.
Peter
Old 12-18-2008, 09:28 PM
gearheadgarage's Avatar
gearheadgarage gearheadgarage is offline
With a little extra effort, the positive cable can generally be run through the factory sill trough, passenger side is easiest since there are no other wires there, most guys mount the batt on the passenger side & the starter is also on the pass side. This makes things a lot cleaner when laying the carpet & installing he upholstery. **definitely suggest a master fuse of some sort, like AAW
In the last few FI cars we've built, we didn't run a ground all the way to the front. We ground the battery to the trunk floor @ the wheelwell & ground the batt directly to the frame rail in the rear. Multiple ground straps up front (engine to frame, frame to body, engine to body) will do the trick. We ALWAYS weld subframe connectors in, so the rear framerail ground coincidentally ties in through the frame rails to the front.
Firewall bulkhead is the way to go.....consider a quality audio distribution block in the pass compartment to tie in additional leads: stereo, power window relays, HID lights....
