Old 03-18-2009, 07:54 AM
chr2002ca's Avatar
Default BMR's new Watts Link for 1st Gen Camaro
Anybody have any opinions on BMR's new Watts Link for the 1st Gen Camaro? It's installation is photo-documented fairly well by www.superchevy.com here:
http://www.superchevy.com/technical/...all/index.html
As is normal with a lot of TV shows and magazine articles, they left me puzzled with part of the implementation. They mention the following:
"The first order of business was to get the exhaust system out of the way. The tailpipe on the exhaust will need to be modified so it doesn't interfere with the Watt's link."
Well, they never ended up 'modifying the tailpipes' in the article, and I'm guessing there's a good reason for that. I'm looking at the final install photos:
http://www.superchevy.com/technical/...m_install.html
Anybody have any ideas how you're suppose to route tailpipes through that? It's interesting that in their final notes about 'all that's left to do after the install' that they don't bother to mention putting the tail pipes back on.
-Chris
https://lateral-g.net/members/robinson/
Old 03-18-2009, 08:47 AM
mazspeed's Avatar
mazspeed mazspeed is offline
It doesn't look all that good. It might work well, but it looks awful
Old 03-18-2009, 09:10 AM
chr2002ca's Avatar
Agreed. It's a bit of a mess under there. Maybe because it's red and it really stands out. If they did a black powder-coat, it might not look so bad.
Chris Robinson
Old 03-18-2009, 09:44 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Maybe I missed it... but how do you set pinion angle with that setup?
My LS7 69 Camaro
Old 03-18-2009, 10:48 AM
Musclerodz's Avatar
I am guessing by the way the torque arm bolts the the third member that girdle is adjustable via shims in the 4 bolt attach points. Only way it could be adjustable.
Mike Redpath
Musclerodz & Customz
facebook page
Old 03-18-2009, 11:49 AM
Rybar's Avatar
Rybar Rybar is offline
I'd like to see how tail pipes are routed, and I'm sure if you ordered it in black would look 100x better
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 03-18-2009, 01:59 PM
BMR Sales's Avatar
The 12-bolt version of our Torque Arm Suspension has a jack screw between the torque arm and rear axle housing. The pinion angle can be adjusted either way with the turn of a wrench.
Old 03-18-2009, 12:53 PM
BMR Sales's Avatar
This product is available in black hammertone or red. The black hammertone is a textured powdercoat and it closely resembles a graphite color. It is different than a gloss black. BMR Fabrication is the only suspension company that offers this color. You can see some examples of BMR product in the black hammertone color at our website www.bmrfabrication.com
We shoot all of our magazine articles with red product. The black hammertone parts blend in with the undercarriage too much and then it's very difficult to see any detail.
Old 03-18-2009, 01:06 PM
Really intresting new product. A lot less work than with other Watt link systems.
63 Z06
Old 03-18-2009, 01:08 PM
BMR Sales's Avatar
-Chris
Routing the tailpipes is the biggest problem with our design. You need to build a custom exhaust since no exhaust manufacturer currently makes a tailpipe that will fit.
It's possible to get a dual 3" exhaust through there. We installed 2-1/2" exhaust on our shop car and there was enough room for 3" pipes.
