Old 08-10-2014, 07:40 AM
ccracin's Avatar
ccracin ccracin is offline
"At Thomson Auto today my LS9 based 427 CID engine made 957 HP at 6400 rpm and 970 TQ 3700 rpm. Over 850 TQ from 2000 to 5700 RPM."
Oh my goodness gracious! Traction control is a must!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 08-10-2014, 07:44 AM
camcojb camcojb is offline
Well that should work nicely!!!
I added a pic of the dyno run, look at the torque.
Old 08-10-2014, 07:52 AM
fleet's Avatar
fleet fleet is offline
The internet is happier now...
Old 08-10-2014, 08:06 AM
For you non-Facebook guys.
Old 08-10-2014, 08:09 AM
Roberts68 Roberts68 is offline
Good grief!!! Sounds very Formula 1ish...
Gotta love the exhaust glowing red hot too... Hellfire for sure
Old 08-10-2014, 08:48 AM
73CPCAMARO's Avatar
73CPCAMARO 73CPCAMARO is offline
Brian Hobaugh
1965 Corvette
1973 Camaro
2003 Z06
Old 08-10-2014, 09:17 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
957HP? What.....are you planning to go the speed of Plaid?
Curtis
Stielow's Avatar
Stielow Stielow is offline
A tick more boost via a blueprinted blower and a slightly smaller pulley. Also a very good inlet tube and reworked blower inlet. On the exhaust side we corked it up to simulate full exhaust via flow restrictors. So I think we will clear 950 HP installed without much trouble. We also use 35 C intercooler water to be more real world. With chilled water we can clear a 1000 HP no problem? Mayhem was fast this should be even faster with more power, less weight,and more down force. If I can get it done!
Old 08-10-2014, 09:48 AM
Jr's Avatar
Jr Jr is offline
Good god!
Is that still a 2.3L blower? 6 bolt heads?
Old 08-10-2014, 10:22 AM
Sieg's Avatar
Sieg Sieg is offline
Turbo's........why?
