Old 07-02-2007, 04:42 PM
55chevyman's Avatar
55chevyman 55chevyman is offline
Default Horsepower and Torque estimate
350 4 bolt main shortblock, bored .30 over, eagle steel crank and rods, LT-1 pistons, Edelbrock Performer RPM head and air gap intake, 750 demon
any guesses would be appreciated
Alex McCarty
1955 Chevrolet 210 2 door post (JOE BEN)
Old 07-02-2007, 06:07 PM
rocketman's Avatar
What compression ratio,what cam roller or flat tappet.without knowing that I guess 350ish hp,270ish tq
Old 07-03-2007, 04:41 PM
55chevyman's Avatar
it is a crane roller cam and the compression is 10 1/2 to 1
Alex McCarty
Old 07-24-2007, 12:18 PM
55chevyman's Avatar
anybody?
Alex McCarty
Old 07-24-2007, 12:19 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Cam specs?
My LS7 69 Camaro
Old 07-24-2007, 04:44 PM
ss dave ss dave is offline
Guesstimate, since my 383 was similar. 332 HP 365TQ on chasis dyno. but need more specs to be more accurate
Old 04-07-2008, 03:43 PM
55chevyman's Avatar
cam specs: 226/226 with .470 lift
just curious, how loud do you think that cam will be?
Alex McCarty
Old 04-07-2008, 04:32 PM
67ragtp 67ragtp is offline
Alex ,
Check out edelbrocks web site they sell crate engines with very similar spec to your engine and you can compare. My guess is 375hp to 400hp at the flywheel. Edelbrock has a 363 hp crate that has a slightly smaller hyd roller cam and 1 point less compression than yours. The cam you selected is pretty mild, should give good vacuum and street manners, will also have a little rumpity rump.
Rich
Old 04-07-2008, 07:26 PM
copo69 copo69 is offline
i will guess 412 hp with 379 tq at the flywheel.
if you cant smoke the tires at 60 mph your engine needs work !
Old 04-08-2008, 09:35 AM
55chevyman's Avatar
thanks, any suggestions on doing anything different?
Alex McCarty
