Old 07-10-2007, 02:28 AM
Default Narrowing the sway bar ?
Can i just cut few inches from middle of the sway bar and weld it back. Maybe in small section of tube over the cut ?
63 Z06
Old 07-10-2007, 07:19 AM
XcYZ's Avatar
XcYZ XcYZ is offline
You can have a custom one bent for you, I know a few members here have had that done.
My LS7 69 Camaro
Old 07-11-2007, 10:28 PM
dav8427 dav8427 is offline
Default Depending on the configuration
If you can get it in the press,you can bend the ends in equally on each end then shorten the ends to get the arm length back to original for no rate change. Depending on end link style new ends could be welded on or you could do what I did and drill/tap the ends of the bar for a 1/2-20 bolt and bolted a heim joimt to the end and made up my own solid end links.
Doug
Old 07-12-2007, 12:07 AM
Thanks Guys!!
I got one for really cheap so its easy to try. Ill let you know how it worked.
63 Z06
Old 07-12-2007, 05:45 AM
Silver69Camaro Silver69Camaro is offline
To your first question, yes you can, assuming it's a plain mild steel bar.
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
