Old 10-15-2007, 03:50 PM
67ragtp 67ragtp is offline
Default Floor jack?
Looking for a good floor jack around 3 ton but low for these lowered cars. Any favorites come to mind?
Thanks Rich
Old 10-15-2007, 05:58 PM
70gotboost's Avatar
70gotboost 70gotboost is offline
We're kinda biased towards these....
http://www.brunnhoelzl.com/WARRIORJACKS.htm
70gotboost
Old 10-15-2007, 08:03 PM
monza's Avatar
monza monza is offline
Maybe a group purchase?
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 10-16-2007, 05:03 AM
70gotboost's Avatar
In all seriousness I have two of these at home and they work great. My ground clearance is just a bit over 4" and these clear with no problems.
Hope this helps!!
http://www.sears.com/shc/s/p_10153_1...Lift+Equipment
70gotboost
Old 10-16-2007, 06:15 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I have the same one, Kevin. I really like it.
My LS7 69 Camaro
Old 10-16-2007, 11:08 AM
Thats more my speed, I think I will take a ride over to sears and see what they have. Looking to spend under 250.00 but want something that will last a bit and hopefully not leak down.
Thanks again guys- Rich
Old 11-13-2007, 06:21 PM
krptonite's Avatar
krptonite krptonite is offline
we used to use one of those jacks but it is in the corner of the shop covered in dust now as no one likes it, this is mainly due to the fact that it has a solid roller at the front it will not roll if there is the slightest hint of grit or debris on the floor. As the car gets lifted the jack doesnt roll under so it trys to pull the jack from under the car, we had it happen with a trainee and a freshly painted all steel 34 coupe, the jack slipped and wedged between the rad and crossmember!! needless to say the boss was none too happy about it, but they do work well if the surface is clean and smooth.
Old 03-02-2008, 05:36 PM
Bulldog68's Avatar
Bulldog68 Bulldog68 is offline
+1 for the Craftsman jack... it operates well and it's low profile enough I don't have to lift on the front bumper to get it under the frame.
68 Camaro - a pro touring project with no end in sight.
70 Chevelle - the one that gets out of the garage every once in a while.
Old 03-02-2008, 05:40 PM
Steve1968LS2's Avatar
I have two of the $99 aluminum units from Costco.. they work fine for me.
Best Of Show had one but after three years one of the wheels broke. But that's a shop putting it through heavy use for THREE years.
Should last me a lot longer..
Old 03-02-2008, 06:18 PM
lil427z's Avatar
lil427z lil427z is offline
I HAVE 3 OF THE CRAFTMAN JACKS . THEYWORK .
RICK K
